02-15-2018, 03:54 PM | #1 |
Anyone convert to a hydraulic clutch?
As asked? I'm considering swapping from the cable deal to a hydraulic and was wondering what was needed. I'm getting ready to swap a 350/4speed into the truck and think it would make it a nicer driver. Other than that. What have you done to make the clutch pedal easier to push? It works well, not binding but if you get caught up in traffic it can make you tired. lol
02-15-2018, 04:43 PM | #2 |
Moderator
Re: Anyone convert to a hydraulic clutch?
Captainfab to the rescue, contact him on that:
http://67-72chevytrucks.com/vboard/s...04&postcount=4 Also lots of info on that here: http://67-72chevytrucks.com/vboard/s...d.php?t=577322
02-15-2018, 05:32 PM | #3 | |
ron |
02-15-2018, 11:25 PM | #4 | |
02-15-2018, 11:25 PM | #5 |
02-16-2018, 12:29 AM | #6 | |
60-66 Nut
Thanks for the mention Rocknrod
Here is the for sale thread for the '63-'66 booster bracket with the hydraulic clutch conversion. http://www.67-72chevytrucks.com/vboa...d.php?t=651200 Quote:
02-16-2018, 08:32 AM | #7 | |
02-17-2018, 10:44 AM | #8 |
I recently installed the clutch linkage kit from LMC thats made with the tubing and Heim joints/spherical rod ends. That, and replacing the little fork shaped thing that goes on the end of the rod to push on the clutch fork, as well as greasing everything up, significantly lightened the effort necessary to push in the clutch. Another plus...the clutch linkage doesn't rattle any more going down the road, either!
02-17-2018, 10:06 PM | #9 |
Interesting. Thanks for that info.
02-18-2018, 02:34 PM | #10 |
Hydraulic bearing, because header clearance and new tko 600
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-18-2018, 05:50 PM | #11 |
02-18-2018, 06:10 PM | #12 |
I used captain fabs pedal kit with a wilwood hyd master on a T56. Very happy with it. light-med pedal pressure.
02-18-2018, 07:04 PM | #13 |
Its a Mcleod, I am sure they have something. Slip on or bolt on snout.
https://www.mcleodracing.com/index.php/hydraulics.html
