Old 11-04-2003, 07:14 AM   #1
gregbr
Senoir Member
gregbr's Avatar
4WD Front Axle question
Can the front 4WD axle be shortened on the hub ends by about 2" on each side. I want to put 4WD under a 54 and the front end in narrower than the 76 the axle & frame can out of. I still need to keep the spring mounts on the axle in the same place since I'm using the 76 frame under the 54. Any comments, I did not want to use a wimpy S-10 running gear.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 11-04-2003, 08:30 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It can happen. I don't know how much it would cost for the machine work or new inner shafts, outers would not change.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-04-2003, 10:31 AM   #3
Dan72cst
Dan72cst's Avatar
I met a guy that put 3/4t chev axels (dana 44 & 14 bolt) under his Wrangler. If I remember right he had to get new axles for the rear, but was able to cut the front axels and have them re-splined. The axel tubs were cut and rewelded.
I have never done this, but just info I gathered by talking to the guy.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 11-04-2003, 12:23 PM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
They can be shortened and it is pretty common in the jeep world as lots of guys narrow dana 60 axles for a jeep.
here are some links:
http://www.4x4wire.com/jeep/tech/axle/yjrcdana44/
http://www.off-road.com/~jweed/dana60.htm
http://www.fabworxinc.com/Automotive...s_narrowed.htm
good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 11-04-2003, 12:59 PM   #5
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
If I am not mistaken the axle on a jeep truck is narrower than one on a Chevrolet truck.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
