02-16-2018, 05:04 AM | #1 |
Active Member
Difference between 60-62 and 63-66 rear suspension
I like the QA1 setup for 63-66 trucks I saw at SEMA. Anyone know what I'd have to do to make it work in my '61?
02-16-2018, 07:35 AM | #2 |
Re: Difference between 60-62 and 63-66 rear suspension
The shape of the frame is the thing you will be fighting. Look in the FAQ section for the frame drawings and that will give you an idea on the differances.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-16-2018, 01:14 PM | #3 |
Pic? I moved my shocks with Porterbuilt stuff.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-16-2018, 02:34 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Lvphotos, is the truck in your pix a 60-62 or 63-66??
Never mind! I see your signature. Thnx
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-16-2018, 02:58 PM | #5 |
It is a true '62 short bed. Porterbuilt was first to have something for this frame. They do have the notches for this frame. I was not planing on it being this low... the pipe notch I made is useless with my shocks, 2" too long
The big issue is the pumpkin hitting wood. In my case 2 pieces in center that are not attached for opening at shows
02-16-2018, 04:35 PM | #6 |
Are those PB cups and trailing arms??
02-16-2018, 07:03 PM | #7 |
Pb arms but Air Ride before Ride Tech "cups" with top plate because 62 cover smaller than cup.
02-16-2018, 07:06 PM | #8 |
Boxed to pb
02-16-2018, 07:08 PM | #9 |
For the notch... 5" pipe 1/4" cut to 2"
02-21-2018, 12:26 AM | #10 |
Active Member
Thanks LV. I don't want to cut my floor up so mine won't be as low. Photo shows QA1 parts.
02-26-2018, 08:30 PM | #11 |
If you get this set up. Show pictures so he all can see.
