Old 02-16-2018, 10:34 AM   #1
Fred n' Ethel
Fred n' Ethel's Avatar
1954 235 Fuel Pump
Hey folks, I have the flat top fuel pump on my 54 - 235.
The body has the 2 valve chambers separated by a partition.
The cap has matching (smaller) chambers with a matching partition.
The rubber gasket between these is a solid sheet isolating the upper smaller chambers from the lower valve chambers.
Is there a purpose for this isolation ?
Maybe the air trapped in the upper chamber is a buffer ? or snubber of sorts ?
Just curious, thanks for your time.
Fred n' Ethel is offline   Reply With Quote
Old 02-16-2018, 02:25 PM   #2
Fred n' Ethel
Re: 1954 235 Fuel Pump
No prob, got this one figgerd out ... once I learned what to search for.
"Pulsator" gasket. Acts sort of like a smoothing capacitor in an AC electrical circuit.
Absorbs the shock, cushions the pulses and actually reduces the noise of the pump.
Kind regards,
Old 02-16-2018, 04:22 PM   #3
mr48chev
mr48chev's Avatar
Well I learned two things out of that. How that pump works and that Fred is getting pretty good with hitting the search button.
My ongoing truck projects:
