Old 02-16-2018, 02:56 PM   #1
Adriangz
65 GMC Radiator Project
Good day all, I'm new to this forum and would appreciate some feedback.
I have a 65 GMC 1/2 ton which I just picked up. Stock motor is long gone, but it it did come with a 305 that appears to be out of an early 80s camaro or caprice. Stock radiator also long gone so I bought a rad off of a 62 V8 Chevy truck. Using the current set-up the new rad sits over 6 inches above the core support. Read some previous posts here and I figure I could relocate the lower cross-member to drop the rad about 3 inches. Apart from this I need the rad to drop in a bit between the edges of the frame. Otherwise I need cut about 3/4" off the frame - "c" notches basically on each side.
I thought that GMC and Chevy were pretty much the same apart from the motors and other smaller details.
Am I doing too much here?
Adriangz is offline   Reply With Quote
Old 02-16-2018, 05:21 PM   #2
forestb
forestb's Avatar
Re: 65 GMC Radiator Project
Sorry Adrian I thought it would be much easier.
forestb is offline   Reply With Quote
Old 02-16-2018, 05:36 PM   #3
raidmagic
raidmagic's Avatar
My truck has been notched by someone in the past. I'm guessing they ran into the same issue you did. I am swapping in an aluminum radiator when I do my V8 swap so I will fix the frame at that time but there are no ill effects of notching the frame horns. You can tell this has been this way for a long time.
raidmagic is offline   Reply With Quote
Old 02-16-2018, 05:45 PM   #4
Adriangz
Hey Forest, It's cool. I like the radiator. I'll make it happen somehow.
Old 02-16-2018, 05:47 PM   #5
Adriangz
Thanks raidmagic. I'm not too far off then.
Old 02-16-2018, 06:36 PM   #6
PGSigns
PGSigns's Avatar
It is cool but wont work. You are going to need a 63 to 66 radiator and the brackets for it make it fit correctly. You have the correct lower mount.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-17-2018, 12:32 AM   #7
Captainfab
60-66 Nut
The '62-'62 radiators mount differently than the '63-'66 radiators. You will have to remove that radiator crossmember to be able to use that radiator. And then you are lacking some support in the front of your frame where it is needed at the steering box.
Old 02-17-2018, 11:19 AM   #8
Adriangz
PGSigns and Captainfab: Thank you for your responses and guidance.
Old 02-17-2018, 02:12 PM   #9
61K10
61K10's Avatar
As the captian said it bolts to the radiator support (the holes should be there) It does not sit in the mounts you show. The 60-62's don't have the bottom mounts and the cross-member they are mounted on. remove the bottom mounts and it should fit.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
