02-16-2018, 11:02 PM | #1 |
Removing Choke And Throttle knobs 67 cluster
I need to remove the cluster out of my 67. How do I remove the knobs off of the choke and throttle. How do I do that?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
02-17-2018, 12:00 AM | #2 |
Roadtrip!
Re: Removing Choke And Throttle knobs 67 cluster
For the choke, pull it out a little bit and hold onto the metal rod with a pliers and unscrew it. For a manual throttle, there will be a little set screw going in sideways like a wiper knob.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-17-2018, 12:24 AM | #3 |
Thank you!
04-09-2018, 02:19 PM | #4 |
Thank you. Big help.
Why would they want to make them all the same.....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
03-12-2022, 06:25 PM | #5 | |
I also thought about disconnecting the choke cable from the carb and pulling it through, but the cable has a little bend on the crab end. I'm troubleshooting my fuel gauge and just want a little peek in. Not wanting to buy a choke cable.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
03-12-2022, 06:39 PM | #6 |
If you are just wanting to pull the instrument cluster out a little bit,
You can remove the screw in the cable clamp on the carb. That is an aftermarket choke cable. Hope this helps.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-12-2022, 07:05 PM | #7 | |
03-12-2022, 07:12 PM | #8 |
I managed to get my hands in behind and there was a nut on back that I could loosen and get some room to see in.
It is an aftermarket cable. Looks like i could disconnect from the carb end and thread the whole cable assembly out, but I just need a peek in to see if my fuel gauge wires are all intact. Sorry for the sideways pictures.!!
03-12-2022, 10:26 PM | #9 |
The Older Generation
There are no actual wires that go to the fuel gauge. There is a printed circuit board on the back of the cluster. What problem are you having with your fuel gauge? LockDoc
03-13-2022, 12:04 AM | #10 | |
I think I have it figured out. I’ve read the other fuel gauge threads and did some sleuthing, and it seems I don’t have a connection between the gauge and the back of the fuse panel. I haven’t had the stock gauge or tank since I’ve owned the truck. It was a saddle tank and an under dash gauge. Now I’m installing a rear tank and wanting to have the stock gauge working. The stock gauge has been pinned at Full (or beyond), which I understand is typical if the sender is not connected (grounded). I plugged a wire from the “fuel ga” spot on the fuse panel to a good ground and the gauge still did not move with the key on. Then I pulled the gauge panel (with some help from the guys above) and connected the sender terminal to a good ground and BINGO the gauge drops to Empty. I can toggle the gauge from Empty to Full by grounding or un-grounding the sender terminal on the fuel gauge. It seems there’s a break somewhere between the gauge and the fuse panel. Maybe the printed circuit panel, maybe somewhere else. But it seems to work if I just run a wire straight from the sender to the gauge terminal, so that’s what I’m going to do. The rest of this “survivor” gauge panel works great, so I think I’ll leave it alone.
03-13-2022, 10:46 PM | #11 | |
Let us know how that works after you get it all wired up and fuel in the tank. That would be good to know. LockDoc
03-15-2022, 05:53 PM | #12 | |
Gauge is working perfectly. Basically just wired it directly from back of gauge straight to the sender. I also made sure I had good grounds on the tank. I poured 2-3 gallons and it showed close to Empty (slightly lower). I added ten gallons (for a total 0f 12-13) and it now shows 3/4 tank. The tank I am using is a Tanks Inc. 18 gallon tank, so the result is pretty close to what I'd expect. I had also set my sender float a tiny bit low, as I plan to leave a bit of room in the tank to make it easier for it to vent. So say if I have 12 gallons in a 16 gallon tank my gauge is dead on. Thanks for all the help guys.!
03-15-2022, 07:54 PM | #13 | |
Good deal. Glad you got it under control... LockDoc
