Post Whore
![]() ![]() Join Date: May 2015
55-59 armrests
has anyone with a 55-59 used a set of arm rest's like or similar to these? I was needing to know what the hole spacing is for mounting...
https://www.ebay.com/itm/Door-Arm-Re...53.m1438.l2649
![]() ![]() Join Date: Nov 2008
Re: 55-59 armrests
I have a new pair outside. I can measure and post tomorrow if no one else knows off the top of their head.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Post Whore
Re: 55-59 armrests
thanks Dan.....
Re: 55-59 armrests
On my 57 there was two threaded holes in the door for original mounting location. I just had to drill the door panel to match. If you have the door panel off you can measure the mounting holes in the door.
1957 3100 ![]() 1950 5 window |
Re: 55-59 armrests
Hello mongocanfly. I've had my truck for a bunch of years and put armrests in not to long ago. The door panels were not punched out for armrests but the door had captive nuts welded in place. To locate the holes on the panel I sharpened a couple of 1/4-20, put them in the door, put the door panel on with a few bolts to center the panel in place and tapped the panel with a hammer to get the exact location for the holes. Hope this helps.
Earl
You have to have patiences or you'll be one. |
![]() Join Date: Sep 2011
Re: 55-59 armrests
If you want to know what they should be measure the threaded holes in your door. Who knows what they did if they are repo.
Post Whore
Re: 55-59 armrests
ok fellers....I guess I should have stated that I don't have a 55-59 truck...so I don't have anything to measure....my bad...these would be for a different project I have going on....i was wanting this info to see if i can make these work....again..I should have stated that at first..
Re: 55-59 armrests
I would e-mail the seller. Depending if they repo'd a car or truck armrest you never know what will come in the box . e-mail the seller . If they won't give you a measurement buy from someone else.
![]() Join Date: Oct 2016
Re: 55-59 armrests
My new ones from brothers are 5 7/8. Not the same part number but listed as 55-56
Post Whore
Re: 55-59 armrests
i did contact the seller of those I listed and all they do is sell parts...they had no clue what the hole spacing was...I mainly put those up as a reference pic
so 5 7/8"....thanks beast...my IH doors have a 7 1/4" hole spacing ...I found some nos but they want something like 300 each for them..and aftermarkets are about 50 each with no hardware or mounting brackets..so I was looking for something close that will work....I can make anything work if I have to...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-17-2018 at 08:52 PM. |
Re: 55-59 armrests
The holes are on the back of the door panels. Be careful, after I mounted mine I didn't realize that my seat was rubbing again them when I pulled the seat forward. I cut the side of my seat.
Re: 55-59 armrests
I recently replaced the ones in my truck (old ones had cracked). Happen to have the old ones right here...holes are 5 7/8" apart.
I also recently figured out that the seat hits when leaning forward. Have to have both doors open to fold seat back forward. |
#13 |
Re: 55-59 armrests
If your door panels are not drilled for arm rest it is real easy to locate the area to drill the two holes if a template is not available. Get two screws that fit the threaded nut plates that hold arm rest in door, and cut the head of screws off to a point use a pliers to screw back in door nut sert. Reinstall door panel and with a slight tap with a hammer a make small dent from the two screws that have a point. This is were you will drill the door panels for spacing.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#14 |
Post Whore
Re: 55-59 armrests
the arm rest holes in my doors are 7 1/4" ctc...but I found some repops so the search is over...thanks guys for all the info
