Old 02-17-2018, 02:31 PM   #1
ccautoupholstery
Starting issue
So my truck has sat for about a yr while been going thru divorce blah blah blah...its now not starting unless i use some starter fluid. The front left bowl on the picture has gas dripping into it but the front right is getting nothing. Im assuming i need to clean the carb but figured I'd ask here. It was running great last yr.
ccautoupholstery is offline   Reply With Quote
Old 02-17-2018, 02:32 PM   #2
ccautoupholstery
Re: Starting issue
The picture rotated, so the bottom left bowl is the one getting gas and above it is not
Old 02-17-2018, 03:00 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
Re: Starting issue
Rear float is stuck. Best thing to do is spend 40.00 and buy a Holley rebuild kit and spray every hole out with carb cleaner.
Jcfcamaro is offline   Reply With Quote
Old 02-17-2018, 03:55 PM   #4
ccautoupholstery
Re: Starting issue
[SQUOTE=Jcfcamaro;8190497]Rear float is stuck. Best thing to do is spend 40.00 and buy a Holley rebuild kit and spray every hole out with carb cleaner.[/QUOTE]
Any idea what rebuild kit to get by chance? I cant find any #s on the carb anywhere and employees in my local parts stores will look at me like im from outer space
Old 02-17-2018, 04:15 PM   #5
geezer#99
geezer#99's Avatar
Re: Starting issue
The number you want is stamped on the air horn.
Look for List—————followed by 4 or 5 numbers.
