Old 11-04-2003, 11:00 AM   #1
C10Squared
truck tilt column worth?
A local yard has a '71-72 truck with a tilt column. What is the value on one of these before I call?
'72 Chevy Custom/10 Shortbed
'77 2wd K5 “Halfbaked”
'93 Indy pace truck
‘70 GMC Jimmy
‘76 K5 Blazer
Follow me on instagram @C10squared
C10Squared is offline   Reply With Quote
Old 11-04-2003, 11:13 AM   #2
dtlilly
dtlilly's Avatar
Good find, usually I see them go for around $200 on here and Ebay.
dtlilly is offline   Reply With Quote
Old 11-04-2003, 11:26 AM   #3
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Man, I can't imagine having a tilt in my truck. The steering wheel is so darn big I can barely put my legs under it as it is! So what do you guys do? Swap to a smaller steering wheel?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 11-04-2003, 11:27 AM   #4
C10Squared
They want $200. I think I'd rather pay another $200 and get a billet unit.
'93 Indy pace truck
‘70 GMC Jimmy
‘76 K5 Blazer
Old 11-04-2003, 11:49 AM   #5
cdowns
cdowns's Avatar
yeah that seems pretty high for a junkyard unit
the reason for having a tilt is some people with lets just say ample stomach proportions can tilt it up and still use the stock wheel
Old 11-04-2003, 12:34 PM   #6
C10Squared
Yeah, I guess I'll stick with my non-tilt one unless I gain a couple of hundred pounds before I'm done.
'93 Indy pace truck
‘70 GMC Jimmy
‘76 K5 Blazer
Old 11-04-2003, 12:45 PM   #7
shuttermutt
I'm no skinny guy, but a little extra room would be nice. I'm seriously considering a different wheel (although I hate to ruin the all-original look of the interior).
'Mutt
Old 11-04-2003, 02:05 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
You can get a tilt collum out of a chevy van much cheaper......and it will bolt in with minimal mods
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-04-2003, 02:07 PM   #9
C10Squared
What all has to be modified on the chevy van columns and what years interchange?
'93 Indy pace truck
‘70 GMC Jimmy
‘76 K5 Blazer
Old 11-04-2003, 02:09 PM   #10
lukecp
lukecp's Avatar
There have been alot of posts on this....since the search function is working, search for something like "van tilt collumn" and you should find the info you need
Old 11-04-2003, 06:20 PM   #11
Broken_down?
---Broken_down?
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 11-04-2003, 07:23 PM   #12
Southpa
Southpa's Avatar
One of the better mods I've done on my truck so far. Van tilts don't come with a steering arm, at least mine didn't. So you have to use the one off your stock column and it has to be shortened about 4". Just drill out the nylon plugs and hammer it in until its the right length. The wiring harness coupler is a different shape, van tilt is halfmoon while stock is flat (or vice versa? I forget). Supposedly there is an adapter out there. I asked at my local GM dealer and the guy looked at me like I had two heads. "Why would you want to do that?" What a dotard. . Anyway, I opted to take the whole works apart and transfer all my old wiring into the van tilt. I think the neutral safety switch has to be relocated as well because the brake pedal arm hits it when aplying brakes. There are ways around that one. I just cut about 3/4" off the end of the switch with a hacksaw. Yes, I literally cut corners when I can. Works like a charm!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 11-04-2003, 11:02 PM   #13
gonebad2
Merciless Butcher
gonebad2's Avatar
Ahhhhhhhhh. The $400.00 billet steering column. I've gone that route. Don't forget to figure in the cost of the polished stainless double D shaft and the vibration isolation rag joint. It adds about another $200 + dollars on to the final cost. They sure are nice though.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
