Old 02-19-2018, 09:48 AM   #1
Jim Boy
Smile 250 Valve Cover Breather Question.
My question is breather or no breather needed? I have read here that some folks recommend installing a valve cover breather in the oil filler hole instead of just a cap. My 235 6's all had one but this 250 doesn't. This engine has the PCV valve at the back of the cover and another hose from the side, at the front of the cover running up to the carb riser. If the answer is to run a breather then why wouldn't GM have put one on the engine to start with? I can only guess that it has something to do with emissions. The answer to my questions usually comes to me in my dreams but no one seems to be listening anymore! Have a good one eh!
Jim Boy is offline   Reply With Quote
Old 02-19-2018, 10:17 AM   #2
geezer#99
geezer#99's Avatar
Re: 250 Valve Cover Breather Question.
On your motor you don’t need one.
You have an air supply from the air cleaner.
You need air in to mix with the fumes and allow the pcv valve to work.
Dreaming, eh!
Of spring time, eh!
We just got a foot of wet snow!
geezer#99 is online now   Reply With Quote
Old 02-20-2018, 11:04 AM   #3
Jim Boy
Smile Re: 250 Valve Cover Breather Question.
Dreaming, eh!
Of spring time, eh!
Thanks. That is what I thought. As far as the snow is concerned it looks real nice with you. We have had enough, my buddy in Calgary keeps sending the crap this way and laughs about it. What's wrong with the people out there eh? Have a good one eh!
