Old 02-19-2018, 01:18 PM   #1
Custom06
Custom06's Avatar
Wheel Geometry is Off
We have an 86 Silverado lowered on McGaughys spindles and removed 1 coil off the original spring. All steering and suspension was replaced with new parts. After the drop we noticed that the driver side wheel and tire sit further out towards the fender than the passenger side which sits in closer to the frame. I have a buddy with an 84 with brand new CPP A-Arms and spindles doing the same thing. Spoke to another enthusiast having the same issue. Any ideas on what is going on???????
Custom06 is offline   Reply With Quote
Old 02-19-2018, 02:15 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Wheel Geometry is Off
Has the truck been aligned yet? It’s possible that one side has different camber than the other, which will move the top of the tire in or out.
I would also measure tire to frame (after alignment) and frame to body on both sides to check if the body is shifted on the frame.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-19-2018, 02:29 PM   #3
Custom06
Custom06's Avatar
Alignment has been done already and still there is a noticeable difference in where the wheel sits in the fender. I would say there's about a 3/4-1" difference. I've got an 85 that we just bought and will be lowering soon. I checked for any issues before lowering this one and it all checks out even on both sides. So if there's any issues afterwards I'll know it's the parts and not the truck.
Old 02-19-2018, 07:03 PM   #4
Dayton601
Dayton601's Avatar
Mine is the same way, I have CCP tubular, with a 2 inch drop spindle, on a 81
measured the drivers side it was about 1.1/4 and the passenger was around 1/2 shims on both sides are about the same , just had front end aligned, drives straight,
Dayton601 is offline   Reply With Quote
Old 02-20-2018, 11:19 AM   #5
Custom06
Custom06's Avatar
I’m thinking the McGaughy spindle is bad???????
Old 02-20-2018, 11:21 AM   #6
Custom06
Custom06's Avatar
I’m gonna buy Western Chasis drop spindles this week for my 85 GMC, we’ll see what that does.
Old 02-20-2018, 02:10 PM   #7
Dayton601
Dayton601's Avatar
Wow seems like after checking the forums this question goes way back in other threads, mine was 4 wheel laser aligned, so feel good about alignment, now it makes me wonder is my body is not off a little, I have new aftermarket body and front core support bushings, might need to loosen and shake it up a little see if it changes anything,
Old 02-21-2018, 07:56 PM   #8
bdiamond
There are 5/8" alignment dowel holes in the front cab mounts. Stick a couple long 5/8" bolts in them to see if the body/ frame alignment is good.
bdiamond is offline   Reply With Quote
