HELP! Can I grind this down?
I'm having header clearance issues. I need to know if I'm going to get into anything important if I grind what looks like excess casting block down? See the red circles. I do know the bottom part I have to leave enough meat for the tranny bolt to hold. Thanks for any responses.
1965 Chevy C10 SWB Step (Family Restoration Project) http://67-72chevytrucks.com/vboard/s....php?p=6043410 1972 Chevy C10 LWB Fleet (factory auto/l6) http://67-72chevytrucks.com/vboard/s...d.php?t=580342 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: HELP! Can I grind this down?
If it were me, I would. I mean it's not me but...Sure, what the heck.
I'm planning to unless somebody says don't. They look like attachment points for the casting/moving machinery to me...
![]() Join Date: Jan 2015
I cut that lower one off on mine.
![]() Join Date: Feb 2010
Closer up pics needed please
Active Member
![]() Join Date: Jul 2007
Question: What engine is it? LSx?
I've worked GM engines and overhauled a few but never really noticed or maybe never paid attention to the extension on the top.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Go ahead and grind them down, leaving enough around the mounting point for the bellhousing. They're not anywhere near the water jacket or oil passages back there. IMO, appears to be casting locator blocks for automated processes. Grind slowly and I did the same on a build and was fine. But I didn't take them all the way down, just enough to clear what was needed.
I will have to look at mine , but looks like that lower boss is for the starter bolt . What year engine is it . The upper one should not be a problem to trim .
I looked at my 6.0 that's sitting in the floor DO NOT GRIND THE SPOT WHERE THE STARTER BOLT GOES..the top spot you have marked it can be grinded some but I would for sure don't mess where the starter bolt goes. now my engine is different its a gen 3 but it should be the same the pic shown looks to a be gen4
4x4k30 if trouble was money i would have plenty |
#10 | |
Thanks for the replies fellas!
60-66 Nut
![]() ![]() Join Date: Mar 2007
I have to ask, what brand of headers are you using that has an interference in those areas? I would have thought by now that all of the LSx headers would fit properly.
#12 | |
You get what you pay for, as always, lol. "Do they fit?" "Crose enough." LOL http://67-72chevytrucks.com/vboard/s...5&postcount=55
#13 |
Active Member
"You get what you pay for, as always, lol. "
Sometimes you gotta do what you have to do to get the truck running. I've been there. I don't know if you saw my question about the year of the engine. I've never noticed the top extension before. Might help someone in the future.
#14 | |
#15 |
![]() Join Date: Dec 2011
"Engine Masters" did a nice episode on headers and how much denting they can handle before you notice *any* power loss. Obviously you don't want to hammer it until it looks like garbage, but the exhaust system is fairly tolerant.
https://www.youtube.com/watch?v=azPKIjxmmdU
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
#16 | |
If you crack or damage the starter area, there isn't a good way to fix it, and without a starter your engine is basically a big boat anchor.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
#17 |
Post Whore
![]() Join Date: Feb 2016
I agree with the previous posts. By all means dimple the headers. No loss of performance or header life. David Vizard talked about this years ago in one of his books as not being a problem.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#18 |
Thanks for the ideas and help guys. I completely cut off the top block even with the surrounding area with no problem. That was the biggest problem I was having. (pic 1 and 2, right and leftside respectively)
Down at the starter bolt, I just cut off the sharp edge and rounded it off. Should be no compromise to strength as I didn't grind any thinner that the thinnest part that was already there. (Pic 3) I'm still going to have to grind the collector rings to clear, but not much. Should be GOOD TO GO!
