![]() Join Date: Jul 2013
Holley carb rebuild question
While tearing the carb down i didnt pay attention to which direction the gold piece went in and in videos ive watched i havent even seen them when they remove fuel line fittings from carb so even necessary?...also my rebuild kit came with 4 different blue gaskets for between the fuel bowl/metering block and metering block/carb...my old gaskets were identical from my primary side and secondary side...am i able to order just these gaskets and not have to buy another 30 rebuild kit? I posted a pic of the old and new gaskets for the secondary side
![]() Join Date: Dec 2011
Re: Holley carb rebuild question
cone faces out.flat end with hole goes in first against spring.We have Advanced Auto Parts stores on the eastern part of country..they stock gasket only packs...Also can go to ebay..type holley carb gaskets and different ones will come up..no need for the whole kit.
#3 | |
It's a filter , fella......
Stan 67 swb BLU MULE posted via flip-fone |
Soooo....how f@&#d am I if one of the float bowl screws got overtightened and in now just spinning?
Dang it! I hate when that happens! I hand tighten. But then my arms are small. Maybe you can heli-coil it?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Sooo f@&#d !
I don't think it's funny.
Sorry, laughin with , not at,,been there 40yrs ago.....
Just listen to Rob
Yea no offense taken, i definitely feel like a dumbass. I hand tightened but it was gushing gas so tightened and checked, tightened some more but too much this time :/ it looks like a heli-coil will be ok for what im needing so im hoping thats the case
Heli - coil will work, use lots of cutting fluid the bodies are made of pot metal. Go slow and make many plunges cleaning your bit. Good luck. I did 4 on a Demon.
Azle |
#13 |
Well after calling around and doing some research, nobody carries part # 108-89-2 which is holleys gasket but there is part # 123-80 that is listed as edelbrock metering block gasket but is identical and in stock
#14 |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
