HOLLEY HP EZ EFI Fuel Injection Complete Kit
I have a Holley EZ EFI kit. I purchased this for a project that I no longer have. The new owner elected to stay with the carburetor. I have opened this box and looked through it but never installed it. Some of the individual boxes in the kit box still have the plastic on them. This cost $1908.00 new at summit and jegs. I will sell it shipped for $1425.00
Holley HP EFI ECU and harness kits allow you to control units like--the fuel and ignition of your engine, along with additional controls for nitrous, boost, or water methanol. Features: * Eight sequentially driven 8:2 peak and hold injector drivers capable of driving up to 16 low or high-impedance injectors are standard * 8-channel distributorless ignition (DIS) outputs capable of directly driving "smart" ignition coils or Holley DIS coils * Integrated, single-channel wideband oxygen sensor control. Works with NTK or Bosch sensors. More channels can be added via CAN bus. * Internal data-logging standard with a huge 2GB of memory * 4-stage progressive nitrous control * Turbo boost control * Integrated water/methanol injection control * Self-tuning fuel table strategy greatly simplifies tuning process * Individual cylinder fuel and spark control allow you to unlock your engine's potential * Compatible with 4, 6, and 8-cylinder engines * Unique lbs./hr.-based fueling strategy greatly simplifies tuning * Advanced idle, closed loop, and enrichment strategies allow for very stable operation * Fully potted and can be mounted in the engine compartment or interior * Sealed automotive and marine-grade connectors * Allows for use of common OEM sensors, as well as customer sensor calibration input * Ignition plug and play with GM 24x and 58x LSx engines, GM HEI, Ford TFI, magnetic, and hall effect trigger, and other ignition systems * 1-5 bar MAP sensor capability * 2-channel knock control sensor inputs for both one and 2-wire knock sensors * Dedicated fuel and oil pressure inputs * Control both stepper and PWM idle air control (IAC) motors * Speed density, Alpha-N, or combination fueling strategies * Four programmable high or low pulse width modulated (PWM) outputs and four fully configurable inputs can be configured for use * Lean or rich safety cutoff [IMG][IMG_5325.jpg](https://postimg.org/image/fdhtnw9b7/)[/IMG] [IMG][IMG_5326.jpg](https://postimg.org/image/qd30zks1f/)[/IMG] [IMG_5327.png](https://postimg.org/image/qpuf5s56b/) |
Re: HOLLEY HP EZ EFI Fuel Injection Complete Kit
This is a complete engine management kit. It does not have injectors, throttle body, fuel pump or pressure regulator. It is only the computer management / electronics with the needed sensors and wiring harness. Since I put complete kit I wanted to clear that up.
I apologize |
![]() Join Date: Sep 2007
I have someone that might be interested in this. can you send me this info to my e mail so I can forward it to him?
sidestep1967@gmail.com
1967custom |
I EMAILEd you
