Old 02-21-2018, 03:23 PM   #1
Adam j
6.2 problems
I have a 6.2 in a 85 chevy k30 that is not running right when it warms up it has no power on top end and acts like it's not getting enough fuel and a lot of blue smoke
Adam j is offline   Reply With Quote
Old 02-21-2018, 04:09 PM   #2
Edahall
Re: 6.2 problems
Make sure your fuel filter is not clogged.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 02-21-2018, 04:29 PM   #3
Adam j
I put a new filter and fuel pump on it
Old 02-21-2018, 04:42 PM   #4
DieselSJ
Re: 6.2 problems
There are a number of things that can cause that. Have you checked pump timing?
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 02-21-2018, 06:27 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
Re: 6.2 problems
Watch this YouTube video, I believe he had the same issues you are having w/ the 6.2 its either this one or the next.
https://www.youtube.com/watch?v=TSU2lvRWeYw
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 02-21-2018, 07:35 PM   #6
Adam j
The truck is running it's just has no power when you give it a lot of fuel it dies and then it doesn't even want to idle right but if you shut it off it will crank back and idle fine until you give it a lot of fuel again
Old 02-21-2018, 08:05 PM   #7
Adam j
Now it will idle fine and have power then all at once it has almost no pedal and when you take your foot of the pedal it shuts off and then will crank right back up and idle good again until you give it a lot of fuel
Old 02-21-2018, 08:22 PM   #8
Edahall
Re: 6.2 problems
You may have an injection pump going out.
Old 02-21-2018, 08:57 PM   #9
Adam j
Would it be acting like that going from good to bad back and forth
Old 02-22-2018, 06:42 AM   #10
GM72K10
Next!
GM72K10's Avatar
Re: 6.2 problems
Pick up sock in fuel tank could be clogged. Especially if truck had been sitting for a while.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
