02-21-2018, 09:37 PM | #1 |
12 bolt Rear End Info
Is there any reason a 1965 GMC 3:73 12 bolt with leaf springs rear end not work on my 66? I currently have a 10 bolt and understand the 12 bolt is a good upgrade even if its not posi.
Appreciate the info. |
02-21-2018, 10:39 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 12 bolt Rear End Info
66 with a 10 bolt?
66’s has 12 bolts stock. Mounts would be the only consideration.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-22-2018, 12:53 AM | #3 |
60-66 Nut
A 65 GMC 12 bolt will be exactly the same as a '64-'70 Chevy 12 bolt aside from having leaf spring mounts as opposed to trailing arm mounts. I do make the trailing arm mounts if you end up needing a set.
02-22-2018, 08:19 AM | #4 |
great thanks, not sure why it has a 10 bolt but it does.
02-22-2018, 08:35 AM | #5 |
Jeff is it trailing arms?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-22-2018, 12:31 PM | #6 |
The 12 bolts i found local is leaf spring. The 10 bolt I have currently is trailing arms.
I didnt know if the 12 bolt was worth grabbing or just keeping the 10 bolt. But it sounds like the 10 bolt I have isnt stock so I am curious what it came off of. |
02-22-2018, 01:24 PM | #7 |
You need to take a close look at the GMC rear and make sure it is not a Dana 44. They were in a good bit of them. I have trailing arm12 bolts if you need one and a Dana 44.
Jimmy
02-23-2018, 08:46 AM | #8 |
my 66 gmc had a 10 stock with leaf springs
02-24-2018, 12:11 AM | #9 |
60-66 Nut
That would be a Dana 44.
02-25-2018, 02:48 PM | #10 |
Got a pic of the markings on my 10 bolt- is this the Dana 44?
02-25-2018, 06:15 PM | #11 |
Nope that's not a Dana. Looks like a car or maybe a S10 rear.
Jimmy
02-25-2018, 09:48 PM | #12 |
so I still have that diff if you want to make a road trip to Nebraska lol!!!, I would throw it on my trailer and bring it to you but I can't find nj in my atlas
02-26-2018, 07:24 AM | #13 |
No need to go all the way to Nebraska. He does need a good 12 bolt.
Jimmy
02-26-2018, 07:43 AM | #14 |
Ya I was just kidding, I built a 12 bolt posi with 373s for mine
02-26-2018, 07:43 PM | #15 |
