Old 02-22-2018, 04:19 PM   #1
bhemingson
Enclosed car trailer question.
I am looking at buying a car trailer. I need it long enough to haul long bed pickups. Is 20 feet cutting it too tight? The next size up is 24' and regardless of length I am going with 5200 lbs axles. Anything else I should consider in a purchase?
bhemingson is offline   Reply With Quote
Old 02-22-2018, 04:34 PM   #2
57Suburb
57Suburb's Avatar
Re: Enclosed car trailer question.
It'll fit, a little tight, but it fits.
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 02-22-2018, 09:25 PM   #3
Greg58
Greg58's Avatar
I own a 24' and have hauled a full sized long-box pickup in it. You need room to squeeze up front to strap down the front. I think a 20' would be uncomfortably tight.
Is there really that much of a savings going with a 20'?
Also consider resale value, I think a 20' would be a harder sell.
You are wise to be looking for 5200# axles. I used mine to haul cabinets for about 10-12 years, then it was totaled in a hailstorm so I bought it back and use it mainly for a garage space now. Good luck.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 02-23-2018, 10:14 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Enclosed car trailer question.
Make sure it has the passenger door in it on the side. Make sure it has the hold downs installed in the floor into the frame of the trailer. Make sure you get one with the roof vents.
The roof vents are the same opening as a roof AC unit so in the future if you decide to put air in it then you just take the vent out and install the AC unit.
I did this back when I had mine. I just put a drop cord end on the unit and plugged it into the power.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
