POL Power Brake System & Clutch Clearance
I am looking at getting a power brake master/booster/pedal/bracket assembly from POL Performance Online, has anyone used this?
I have a 53 3100 with a S10 frame & 5.3l. Under the dash is bare, blank slate. If so, will I have room for my clutch & master? https://youtu.be/Cyg7r1fW-rM https://www.performanceonline.com/19...e-Booster-Kit/
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
Re: POL Power Brake System & Clutch Clearance
Maybe this photo will help:
Yes it does, thank you. I haven't seen one with a steering column yet.
With that setup I don't think I will have room for a clutch, even a reverse mount one.
