Old 02-23-2018, 07:20 PM   #1
71chevyJim
Speedometer gear for TH400 transmission
My truck's speedometer shows about 75mph when I think I am going about 45 to 50 mph. Can anyone tell me how many mph one tooth on the driven gear will change the speedometer? The driven gear that is in there now is a 40 so do I go up in teeth or down. I am thinking going up will bring the speedometer down. Any help will be great! Thanks Jim
71chevyJim is offline   Reply With Quote
Old 02-23-2018, 07:39 PM   #2
harpo231
harpo231's Avatar
Re: Speedometer gear for TH400 transmission
correct !! you need to confirm actual speed and one tooth = 5% of speed.... do da math....
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-23-2018, 07:48 PM   #3
71chevyJim
Stan, Does that 5% mean about 5mph?
Old 02-23-2018, 08:09 PM   #4
harpo231
harpo231's Avatar
depends on actual subtracted from gauge
Stan
67 swb BLU MULE
Old 02-23-2018, 11:06 PM   #5
HO455
Post Whore
HO455's Avatar
Only at 100 mph. 2 1/2 mph at 50.
RIP Bob Parks.
Old 02-24-2018, 01:26 PM   #6
71chevyJim
Thanks Bob for the input, I will try a higher gear to see if that will lower the speedometer.
Old 02-24-2018, 01:31 PM   #7
71chevyJim
One more question, Does it make a difference if the drive gear is 15 or 16 tooth?
Old 02-24-2018, 05:25 PM   #8
HO455
Post Whore
HO455's Avatar
Yes it does make a difference on the driven gear. You want to go up in size on the driven gear or down in size on the drive gear to get a lower indicated speed. Here are some links that may help you.
Good luck
http://www.wallaceracing.com/speedo-calculator.php
http://www.tciauto.com/tc/speedometer-gear-calculator/
http://www.gtsparkplugs.com/SpeedoGearCalc.html
RIP Bob Parks.
Old 02-25-2018, 01:38 AM   #9
dell72
What is your rear gear ratio and tire height?
dell72 is offline   Reply With Quote
Old 02-25-2018, 02:26 PM   #10
71chevyJim
My rear axle is 3.73 and tire height is 27 inches
