02-24-2018, 12:16 PM | #1 |
Rear trailing arm spring info wanted
Good morning! I have a mystery spring set that I am trying to identify. I've searched and have not yet found a spring reference chart or what ever for our trucks springs? I would like to know stock spring heights, un sprung and compressed and the values of the springs? Mine is a lowered spring so I just wanted to reference stock heights and weights so I could determine the best spring to go with because .ine are to low. Hope this is a good explanation? Thanks for any help you can give!
02-24-2018, 12:48 PM | #2 |
Re: Rear trailing arm spring info wanted
I would call any of the many vendors for info. Or if you got a spring builder in your area. I know one here in Vegas might have some old books.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-24-2018, 12:50 PM | #3 |
I sold my stock 1/2 ton to friend with panel got 2" drop with weight
02-24-2018, 05:40 PM | #4 |
Hey thanks, what are the chances you could put a tape measure on that spring? Just need a rough estimate to get started. Thanks for the tips I'll call moot and eibacj or someone and just ask Lol! I just enjoy the forums now and again. Thanks again Charlie
02-24-2018, 06:54 PM | #5 |
Long gone
02-24-2018, 09:09 PM | #6 |
I did a lot of looking for spring info last and here is the tread on spring rates. Most are pretty close and there are really not much for the back of a suburban. Several things can change the drop you get from a set of springs, long or short bed, engine and trans and fuel tank location are just some.
Jimmy http://67-72chevytrucks.com/vboard/s...t=spring+rates
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-25-2018, 02:09 PM | #7 |
Thank you! I know you are following the "make it handle" thread. I am just copying some of theirs and your recommendations. Got the truck off the ground last night and i should deffenitly address some of these issues and its fun. Todays my 50th and my present to my self is working on the truck lol! I wont go over board though just trying to be safe and sound.Thanks for helping a guy out!
02-25-2018, 06:16 PM | #8 |
Happy Birthday.
Jimmy
