Old 02-25-2018, 01:53 AM   #1
rvc2017
Holley 3310-10
I bought a used 3310 and currently rebuilding it, But i can not figure out where the balls in the rebuild kit go?
Also on the manual choke is there a spring that goes in the fast idle cam plate? It looks like something goes in it, but mine doesn't have anything.
rvc2017 is offline   Reply With Quote
Old 02-25-2018, 10:51 AM   #2
geezer#99
geezer#99's Avatar
Re: Holley 3310-10
IIRC the check balls are for the accelerator pumps.
Look in here for your carb. There should be a pic to help with that.
http://www.carburetor-parts.com/Free...ls_ep_274.html
On the manual choke there’s a spring with a tiny button that goes in the hole. Most people who ran them took it apart and threw the button and spring away. The button usually got gummed up and the choke was hard to move. It’ll run fine without it.
geezer#99 is online now   Reply With Quote
Old 02-25-2018, 07:15 PM   #3
68Gold/white
Re: Holley 3310-10
There's a check ball between the secondary diaphragm housing and the main body, DO NOT leave that one out!
68Gold/white is offline   Reply With Quote
Old 02-25-2018, 10:59 PM   #4
jocko
jocko's Avatar
Re: Holley 3310-10
Originally Posted by geezer#99 View Post
What a GREAT link, thanks geezer.
Old 02-26-2018, 01:09 AM   #5
rvc2017
Re: Holley 3310-10
Is that the one that actually you put in the top of the passage that goes from inside of the diaphragm, down into the carb body?
