Old 02-25-2018, 05:30 AM   #1
Detmar
Detmar's Avatar
Rear suspension question
Is the leaf coming from the rear of the truck not touching anything normal? What Am i looking at? And i can't get the dang picture to upload correct.. i flipped it and its still upside down. So my apologies.
Detmar is offline   Reply With Quote
Old 02-25-2018, 05:31 AM   #2
Detmar
Detmar's Avatar
Re: Rear suspension question
And now it's correct.. even though the preview showed it wrong..
Old 02-25-2018, 05:36 AM   #3
Aus69c20
Aus69c20's Avatar
It’s an overload spring. It only touches under a heavy load and helps bear the weight.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 02-25-2018, 06:36 AM   #4
Detmar
Detmar's Avatar
Thank you my initial thought was they were something like that. Now that i know what they are called. I quick Google search gave me some great info. Helper springs seems to be another common name for them.
Old 02-25-2018, 04:17 PM   #5
Mike C
Mike C's Avatar
Usually helper springs are an add on for leaf springs. The overload leaf on your truck is a GM factory option for the coil spring rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-25-2018, 08:43 PM   #6
Detmar
Detmar's Avatar
Thanks for the info! Love learning every detail about my truck. just read that its a stock 3.73 rear end it as well. on the spid anyways now to see if its in there still. i think its a 12 bolt main.
Old 02-25-2018, 09:25 PM   #7
Mike C
Mike C's Avatar
It is a 12 bolt. But main has nothing to do with the rear axle. Enjoy your truck as it sounds like you are!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-26-2018, 12:42 AM   #8
Aus69c20
Aus69c20's Avatar
Unless you’re using your truck to cart heavy loads on a regular basis you could probably remove them. They weigh a fair bit and are relatively easy take off or replace if you need.
My truck leads an easy life now so I took mine off.
John
Old 02-26-2018, 02:39 AM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Pop the cover off your differential to see if you have a 12-bolt posi, and drop the oil pan to see if you have a 4-bolt main motor...Enjoy your classic ride!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
