Old 02-26-2018, 10:25 AM   #1
Chevyland
Chevyland's Avatar
? SPID ? Why do some have (order no.) in lower right
Most spids do not have
‘order no.’
At lower right
If one does
WHY ?
Chevyland is offline   Reply With Quote
Old 02-26-2018, 10:28 AM   #2
Deer_hunter_088
Deer_hunter_088's Avatar
Re: ? SPID ? Why do some have (order no.) in lower right
Most likely the truck was custom ordered, and thats the number of the order.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 02-26-2018, 02:11 PM   #3
Keith Seymore
Keith Seymore's Avatar
Plant to plant variation, based on their preference.
Every truck is "ordered" (and "sold"), either by the customer specifications or by a dealer for generic dealer stock before it is built. There is no way to differentiate at this point, unless you were able to get the invoice from the GM Heritage Center (which you can't until 1976 ish) and it showed a customer name on the invoice.
The dealer order number is the primary tracking handle until the order is forwarded to the appropriate final assembly location, at which time a concatenated PVI ("Primary Vehicle Identifier"), CSN ("Carrier Sequence number") and General Assembly ("GA") sequence number are created.
At that point the GA sequence number is the primary identifier of the vehicle until it leaves the assembly plant. Once it leaves the plant the VIN takes over that role.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-26-2018, 02:18 PM   #4
Dustmaker65
Dustmaker65's Avatar
Thanks for the info Keith!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 02-26-2018, 02:21 PM   #5
Keith Seymore
You are welcome.
Really - I just wanted to say "concatenated".
Concatenated.
K
1979-1986
1986 - 2019
Old 02-27-2018, 09:30 AM   #6
I have only seen these numbers on a limited number of trucks, so also assumed these were special orders. Another "why" to ponder.
Yeah yeah, the PVI, CSN, and GA. Who doesn't know all that? What I don't know is what the heck does concatenated mean?? Must be a derivative of concocted cuz I think you just made it up!
Old 02-27-2018, 10:05 AM   #7
Chevyland
Chevyland's Avatar
THanks for the info Kieth
With all that being said
It sounds like there is really no answer WHY some trucks have (order no)
On the spid
It just depended what each plant felt like doing ?
I always assumed it was a truck that had been Specically ordered by a customer
Vs , one that was a group order by a dealership
Old 02-27-2018, 10:53 AM   #8
Keith Seymore
"Concatenated" means "linked together, in a chain". I only learned that a few weeks ago but I can use it here because these numbers are created and released in that order, and are forever linked together.
Actually - It gets worse. If the vehicle is destined for Engineering or Marketing use it will get a "fleet" number for use while it is in GM service. Like "CP5085" (two wheel drive pickup, 1985 model year, 1/2 ton, sequence number 85) or "KS7187" (4wd Suburban, 1987 model year, 3/4 ton, number 87).
So - I have to "translate" depending who I am talking to in order for them to know which vehicle I'm talking about.
If the order is still at Central Office I use the Dealer Order number.
If it's in the body shop at the assembly plant I use the PVI.
If it's in the trim shop I have to use the CSN.
Once it gets to the Final Line everybody uses the GA sequence number. Nobody ever cares about the VIN in the assembly plant.
Or, if it's in service at the Milford Proving Ground, then I have to refer to it by its fleet number.
It gets kind of complicated, especially if you are building (or have just built) eleven hundred or twelve hundred pre-production units.
K
1979-1986
1986 - 2019
Old 02-27-2018, 11:02 AM   #9
dave6672
dave6672's Avatar
My C20 Highlander has as order number as well on the SPID. What about the number that is at the top of the SPID towards the right side (376704 on my SPID pic). What does that indicate?
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
dave6672 is offline   Reply With Quote
Old 02-27-2018, 11:32 AM   #10
a1vintage69
a1vintage69's Avatar
I have noticed on my CST K5 Blazer, all the Cheyenne's and the Super all have order numbers and the customs do not. might be a coincidence . a1
a1vintage69 is offline   Reply With Quote
Old 02-27-2018, 01:03 PM   #11
Keith Seymore
I'll have to give that some thought.
Mine is 515906, which doesn't correspond to anything obvious:
Not the last six of the VIN.
Not the GA sequence number (mine was number "87". I don't know the full sequence number).
Not a model number. Not a build date. Not the order number.
Maybe it's the PVI or CSN.
So - not sure.
K
1979-1986
1986 - 2019
Old 02-28-2018, 08:22 AM   #12
Owning these trucks has been a concatenated experience for me since '73. I hope I can keep on concatenting on, as Joe Dirt might say (once the word was explained that nobody ever knew).
I have seen variations in SPIDs of many sorts. I always wondered about the trucks with no info in the WB box or special paint code up in the SE box. That 39xxxxx number on dave's SPID might be the part# for the SPID? Sure looks like a PN to me (didn't run it)
Old 02-28-2018, 09:23 AM   #13
LockDoc
The Older Generation
LockDoc's Avatar
I haven't checked the rest of my trucks but my Cheyenne Super SPID has an order number on it.
LockDoc
Leon
Old 02-28-2018, 12:41 PM   #14
Keith Seymore
That’s correct: the seven digit number 3986681 is the part number for the blank adhesive label.
I was referring to the six digit number 376704.
K
1979-1986
1986 - 2019
Old 02-28-2018, 12:58 PM   #15
harpo231
harpo231's Avatar
Me thinks these spids create more questions than provide answers.... just enjoy the trip !
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-28-2018, 02:32 PM   #16
Chevyland
Chevyland's Avatar
That’s ok!
We all enjoy the trip around here
Since we’re All talking about the same trucks
But
Me like to to find new information
They, didn’t learn me in school
Old 02-28-2018, 02:57 PM   #17
atog
Could it be the dealers allocation number or the number when it got preferenced?
atog is offline   Reply With Quote
