02-26-2018, 11:45 AM | #1 |
Hardwired dash
Old circuit card worn and didn't fit exactly enough to span across the tach install. Lost a few connections, mostly signal indicator lights, so I built a harness. Sure there's a few things I could've done differently but it works. That's more than I could say for the circuit card.
02-26-2018, 11:49 AM | #2 |
Re: Hardwired dash
Nice work! I've wondered about this mod and how easy it would be. You've made it look good and easy.
Any tips or tricks you've learned?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
02-26-2018, 11:57 AM | #3 |
Re: Hardwired dash
Thank you. Took a full 8 hour day of straight wiring (for me) to get it done. The twist lights need to be trimmed to fit and everything mapped. Used a Deutsch connector and crimping tool. Worked out ok.
02-26-2018, 12:29 PM | #4 |
People know me
Re: Hardwired dash
That looks great! Where did you find the harness connector? When I did the autometer setup in mine I ended up using a few 4 wire trailer/vehicle harness plug/connectors and just wrapped colored electrical tape around them to designate what connected where.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
02-26-2018, 07:23 PM | #5 |
Re: Hardwired dash
Beautiful Job!
Thanks for sharing.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
02-26-2018, 09:22 PM | #6 |
Re: Hardwired dash
Very nice and clean.
02-26-2018, 09:50 PM | #7 |
Re: Hardwired dash
Do you have any build pics or steps on how you did this, and how its connecting to the Truck.. I would be interested in do this as well.. looks awesome.. and very clean
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
02-26-2018, 11:00 PM | #8 |
Re: Hardwired dash
Where did you get connector?
02-27-2018, 10:25 AM | #9 |
Re: Hardwired dash
Thank you. The harness connector is a Deutsch DT 12 pin from online. Wirecare.com has them but there are others. That's just the one I used. Were I to do it over, I think it might be easier to use two 6 pin connectors.
02-27-2018, 10:28 AM | #10 |
Re: Hardwired dash
02-27-2018, 10:29 AM | #11 |
Re: Hardwired dash
02-27-2018, 10:32 AM | #12 |
Re: Hardwired dash
Thank you. Yes I have pics of the steps and I will gladly share them. Unfortunately, I will be very busy for the next two weeks so It may be a short while before I can make a thread. But I will.
02-27-2018, 10:38 AM | #13 |
Re: Hardwired dash
The connector came from Wirecare. I purchased a kit with the 12 pin and crimping tool.
The connector is high quality, weather resistant and the pins are nickle plated. You'll have to assemble the pins and barrels with this type of connector and that will require their crimping tool. The pins/sockets (male/female) are closed barrel connection and the have an outstanding grip when crimped with the appropriate tool. It's unlikely that the pins/sockets will fit into the housings if, for example, they are crimped using pliers or a tool not specifically designed for the size and type. Last edited by Richard2112; 02-28-2018 at 11:23 AM. |
02-27-2018, 04:15 PM | #14 | |
Re: Hardwired dash
Sounds good. Thanks..
