02-27-2018, 07:04 PM | #1 |
1971 c10 gauge cluster
I have a basic gauge package in my 71 c10 being speedo and fuel and in the center two idiot lights with turn indicators. I bought a used gauge cluster out of A 72 c10 super cheyanne that also has temp oil pressure and volts. My question is will my wiring that went to the basic gauges work on the better gauge package?
02-27-2018, 07:13 PM | #2 |
Re: 1971 c10 gauge cluster
jagwarman
You will need to modify the wiring at the connector Check this link under tips for the wiring change http://www.gmcpauls.com/Tech%20Tips1.htm
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
02-27-2018, 07:25 PM | #3 |
I will look at this link. Thank you
02-27-2018, 10:26 PM | #4 |
Cluster King
http://67-72chevytrucks.com/vboard/s...d.php?t=645940
Also check out this thread. It will explain how to change the terminals from one location to the next in the connector. Everything you need is there minus the wiring for the amp gauge which is terminal 1 and 12 in the connector. I offer volt gauge conversions as well which eliminate the amp gauge and the need for amp gauge wiring. Let me know if you have any questions. I have helps a lot of members here do the exact same thing. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
02-27-2018, 10:38 PM | #5 |
Thanks so much for the help.
02-27-2018, 10:57 PM | #6 |
I have also done away with the voltage regulator and converted to a 1 wire alternator which is not even running to the current idiot light. That will have to be sorted.
02-28-2018, 12:37 AM | #7 | |
Msgt USAF Ret
The ammeter or the voltmeter will work with the one-wire alternator if they are correctly wired into the harness.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
