Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 02-28-2018, 01:04 AM   #1
Rob 61 apache
SWB 61 apache
This is a first for me,i started this project about a year ago,I’m planing to rest o mod it thinking about a 327 with a 400 tranny,and a front end swap as the original was all cracked up,I noticed my dif was welded so I’m changing that also,I wanna put power steering,my cab needed cab supports,pillars,inner/outer rockers,the back of the cab was rusted thru,floor pans,inner foot plates and I’m sure I forgot something,i have been getting a lot of great info from this site,I’m not that good with computers so I’m having trouble getting some pictures up,any help would be appreciated
Rob 61 apache is offline   Reply With Quote
Old 03-27-2018, 02:39 PM   #2
Just-in-credible
Just-in-credible's Avatar
Re: SWB 61 apache
So, if there is any one piece of advice that I can give you from my build, it would be to look into an overdrive transmission. I have 3.73's in mine, and the overdrive was like night and day. I see you're also from Alberta! I live in Calgary. Before I had the OD in mine, keeping up with traffic on the QEII was not fun. I drive to the red deer cruise every once in a while, and frankly, it sucked. I got a 700R4, and it was like a whole different machine. At the same time as I did the overdrive, I put in a dakota digital cruise control unit. I actually want to drive it everywhere now. I can scoot down the QEII, set it on cruise, and actually pass people.
I have an extra 700R4 kicking around if that would be something you'd be interested in.
Just-in-credible is offline   Reply With Quote
Old 01-06-2019, 12:25 PM   #3
Rob 61 apache
Re: SWB 61 apache
Hey,sorry about taking so long to reply,I finally got my 71 suspension almost into my 61,did a lot of research and I think you’re right about using a 700 r4,so now I’m looking for a motor and tranny,any suggestions for motor to go with the 700 tranny,and do ya still have a spare 700 kicking around
Old 01-06-2019, 04:39 PM   #4
Wikid61
Wikid61's Avatar
Re: SWB 61 apache
You keep looking for a running driving sbc/700r vehicle & score all the extra parts needed to make this swap happen. Also research what others have used to upgrade these older trucks. Shifter? Floor aftermarket or a column mod (very involved for most) is another question to be put to a check off list. Drive shaft. A '71-'72 5 lug rear end to match the front.
Wikid61 is offline   Reply With Quote
