Old 02-28-2018, 10:06 AM   #1
bubbasimms
Opinions on a 205/60-15
Good morning all:
I recently got some refinished 5 lug 15x6" white steelies with caps to put on my project 69 stepside. Converted to 5 lug and disc, lowered with 2 1/2" spindle and 2" Blocks and a basic 4 corner air bag job.
Searching for some tires for the new 15x6 steelies and found some Goodyear Eagle 205/60-15's for cheap. Apparently the 205 is max width for the 6" wheel but I am thinking they may be too short at about 25" tall.
Anyone running a similar setup? Does it look goofy, too small in the wheel wells? I am already gonna be pushing the rpm's on the highway with the 3 speed and the 373's so if they look goofy as well I'm gonna keep looking.
bubbasimms is offline   Reply With Quote
Old 02-28-2018, 10:20 AM   #2
sick472
sick472's Avatar
Re: Opinions on a 205/60-15
It's merely my opinion, but 25" tall tires will look too small under a truck even if it's lowered. The photo of my truck in progress has 15" rims that are 8" wide with 205's or 215's (I think, I would have to double check for the true size). Keep in mind that my truck has a 1" body lift and car tires on 8" wide wheels sit even lower, but LOOK at all the air in the fender front and back...I can check the overall height of my tires regardless of actual size specs if it helps you.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-28-2018, 10:24 AM   #3
bbrriiaann1973
I like the largest tire possible that can fit on the truck. I have 295/50R15 up front and 325/50R15 on the rear
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-28-2018, 10:24 AM   #4
bubbasimms
Oh yea... thats goofy for sure.. better keep tire shopping. thanks a million
Old 02-28-2018, 10:47 AM   #5
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Originally Posted by bubbasimms View Post
Good morning all:
I run 275/60/15 Rear 235/60/15. I just changed from 3.73 to 3.07. Highway driving is way better. Can imaging the RPM with smaller tires.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 03-01-2018, 09:41 AM   #6
sick472
sick472's Avatar
Bubba, FYI - the tires on my truck are 205/65-15 and they measure 24" diameter at the sidewall and 25" at the center due to being too small for that wide of a rim. They are just on there until the time comes for new wheels and tires.
1972 C10
1985 K20
Old 03-01-2018, 10:05 AM   #7
bubbasimms
Great to know....thank you much for the info
