Old 03-01-2018, 10:25 AM   #1
4x4k30
4x4k30's Avatar
ls engine mount problem
I bought the speed engineering www.speed-engineering.com ls swap plates and I am having trouble getting the right side engine mount bolt in .. it is off about a inch the left side bolt will go rite in been fighting for a couple hours with no luck i have set-in a few engines never had a problem like this and don't know whats going on any ideals ?? its going in my 79 k20
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 03-01-2018, 11:49 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: ls engine mount problem
That link just went to a generic ebay search, not any products.
When you say right, do you mean driver side? Also, in what way is it off? Too far forward, inside, outside etc?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-01-2018, 01:05 PM   #3
4x4k30
4x4k30's Avatar
I found part of the problem I have the right pass. side motor mount on back asswards where it bolts to the truck frame mount bracket ..will post pics soon gona go try it again.
Old 03-01-2018, 03:53 PM   #4
4x4k30
4x4k30's Avatar
I swapped the motor mount around like it should be and still the right side pass. side will not bolt up the motor mounts it likes about a inch see pic see the yellow spot that's were it needs to be see the hole where the bolt goes into the frame mount.. the left side is bolted in like it should be. I am stumped
Old 03-01-2018, 07:25 PM   #5
71cadc10
71cadc10's Avatar
check the clamshell half that bolts to the block adapter...see if it's hitting the block right above the oil pan rail.
clearance the clamshell so it can bolt up flush to the block adapter.
that's where mine hit anyway.
are your Frame stands the SB style? I believe they need to be that type, but I"m not all that familiar with the 79
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 03-01-2018, 11:26 PM   #6
4x4k30
4x4k30's Avatar
well its not hitting where you are talking about.. I measured the distance from the motor mount to the front of the transmission so that's where I set the motor mount bracket that mounts to the block so it should fit rite its the only way it will fit I used the second hole of the aluminum ls swap plated to bolt the factory 3 bolt bracket that goes over the clamshell rubber motor mount the engine set in like it is supposed to do but if you look at pic where the yellow spot is you can see that that's where the one of these motor mount bolts should be its in the left side fine I am stuck
Old 03-01-2018, 11:48 PM   #7
mongocanfly
mongocanfly's Avatar
your link above still don't work...can't see what your adapter looks like...
when I put mine in I had the motor mounts bolted to the crossmember,
I had my adapter plates and clamshells bolted to the engine...it dropped straight in and lined up perfect...its hard to tell what you got going on in the pics
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-02-2018, 12:06 AM   #8
4x4k30
4x4k30's Avatar
its these plates from steetrays
Old 03-02-2018, 01:17 PM   #9
4x4k30
4x4k30's Avatar
I emailed speed engineering and they emailed me and said to send them back. they said they don't know what the problem is they said that they have never tried them on a chevy k20. so I have another set of plates coming from another company called jllfab so I have to wait a few more days before I get them and try them they said theres would fit the k20.
Old 03-02-2018, 08:16 PM   #10
4x4k30
4x4k30's Avatar
I talked to speed-engineering today and we still do not whats wrong I did send some pics to them today and when I took them I also took some of a 79 gmc c2500 2wd that I have and did notice they are different than the 4x4 the 4x4 frame motor mount brackets are bolted in from the bottom and the 2wd are bolted in to the top of the frame see pics hopefully get something figured out soon
Old 03-03-2018, 07:35 AM   #11
71cadc10
71cadc10's Avatar
I'm using parts like in your last 2 pics, 2wd stuff. drops right in
Old 03-07-2018, 10:36 AM   #12
4x4k30
4x4k30's Avatar
update I got my ls engine set in my 79k20 my problem was the speed engineering mounts are used to install to 2wds not 4x4 the 2wd drive engine mounts are 17 and 1/4 from center to center and the 4x4 engine mounts are 16 and 1/4 . I bought a set of ls swap plates off ebay jjbb99 and they worked great they will work on 2wd and 4wd. when I first put them on and they measured 17 1/4 for the 2wd but these plates are made to just swap from one side to the other . so I swaped them around after I called the guy I bought them from and he told me just swap them around from one to the other and they measured 16 and 1/4 .
Old 03-07-2018, 10:46 AM   #13
mongocanfly
good deal...I never there was a difference between 2wd and 4wd....
Mongo...aka Greg
RIP Dad
RIP Jesse
