11-04-2003, 08:44 PM | #1 |
cutting springs
Has anyone cut their coils to drop their pickup. I saw these project in an old car craft magazine. I was wondering what your opinions on this is. Also how you guys did it if you did do it. Thanks
11-04-2003, 08:49 PM | #2 |
PROJECT 7DEUCE
I would not do it but, it is not my truck. If you do cut the spring's use something the will not build heat(like a torch)to cut the spring's... Lowered spring's are cheap these day's why not get a nice ride and the truck will stay level..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-04-2003, 08:55 PM | #3 |
Yes it can be done. I had mine cold cut. But I beleive you can only cut the front ones as the back are tapered. It possible by cutting that you will decrease the ride (smoothness). I forget exactly how much each coil drops the truck but it is a pretty good bit. Easiest/safest route would be the ECE drop coils or similar. - Jeremy
11-04-2003, 09:01 PM | #4 |
Watch out for your cornhole !
I've cut gobs of springs before.
On these trucks, 1 coil= 3 inch drop (on the front)
11-04-2003, 09:42 PM | #5 |
personally i dont think its worth the hassle if you want to lower your truck do it right and safely just buy new springs they arent that expensive
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-04-2003, 10:24 PM | #6 |
71 DELUX
yep
I've done it, lots of times, lots of vehicles. Very EZ...I've never cut them any other way than with an angle grinder. I WAS shocked that cutting only one coil dropped the truck 3" but that is what happened. My ride quality is fine...don't bottom out, very smooth...still a better ride than my 2001 truck! My two cents.
11-04-2003, 10:28 PM | #7 |
Formerly yellow72custom
In an older Classic Trucks, they reccomended putting the coil in a bucket of water up to the level of the cut, and loping it off with a torch. I guess the coils are tempered, and heat can ruin a temper....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-04-2003, 10:31 PM | #8 |
Fabricate till you "puke"
I cut my front springs several yrs ago, before drop springs were available for the 67-72s. I got a new set , & cut 1 ring off(3" drop, as earlier posted). I turned them upsidedown in a 5 gal bucket of water, & torched off the exposed end. For what its worth, the truck doesnt ride bad, but you will need shorter shocks, or shock relocators. Eventually , I will get around to spindles & bags. drop springs are cheap,& spindles are really a better way to go. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-04-2003, 10:56 PM | #9 |
YEP -- I'VE CUT A FEW. I USED A AIR POWERED CUTOFF TOOL. NO HEAT AT ALL. H@LL I COULD TOUCH THE SPRING 1/2" FROM THE CUT AS SOON AS I FINISHED. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
11-04-2003, 11:28 PM | #10 |
I've dropped a dozen or more trucks by cutting 1 round out of the bottom of the front springs and then using 2" schedule 40 tuben for the drop on the rearend with some long u bolts from Advance Autos Parts! And I got a 69 to do this weekend!
Things happen for a reason! |
