Old 03-01-2018, 11:16 PM   #1
StrokinRat
StrokinRat's Avatar
Inside rim lip hitting PB control arms
I put brand new porterbuilt upper and lower control arms on my 85 last weekend. I’m having a problem with the inside lip of my rims hitting the control arms when I turn sharp. There are no steer stops so I’m not sure what I’m supposed to do about this. Any suggestions?
I have contacted PB but haven’t heard back from them.
Sorry the control arms are filthy but it’s been raining here.
85 Chevy C-10 383 stroker
StrokinRat is offline   Reply With Quote
Old 03-01-2018, 11:20 PM   #2
Dayton601
Dayton601's Avatar
Re: Inside rim lip hitting PB control arms
What rims do you have, I'm sure it has mostly to do with back spacing,
Dayton601 is offline   Reply With Quote
Old 03-01-2018, 11:24 PM   #3
StrokinRat
StrokinRat's Avatar
I figured that. 17” eagle alloy. I can’t remember the off set though. I bought them 9 years ago.
Old 03-02-2018, 09:07 AM   #4
HunterRotten
HunterRotten's Avatar
My cragars were going to hit the knuckle on the drop spindles I got from mcgaughy. I ordered a .25" spacer to fix the problem. There's a picture that's relatively recent on my build thread of it.
HunterRotten is offline   Reply With Quote
Old 03-02-2018, 11:21 AM   #5
RotaryRocketeer
RotaryRocketeer's Avatar
Small wheel spacer, ftw. At least to get you by.
RotaryRocketeer is offline   Reply With Quote
Old 03-02-2018, 11:59 AM   #6
StrokinRat
StrokinRat's Avatar
Yea I believe I’ll try the spacers. I’ll make some kind of spacer this weekend to see what size I’ll need to go with.
Old 03-02-2018, 12:20 PM   #7
HunterRotten
We used washers and put the wheels on with 2 bolts until it cleared, measured the stack of washers and went to look for a spacer about that size.
Old 03-03-2018, 08:40 AM   #8
StrokinRat
StrokinRat's Avatar
Thats what we are going to do today. I liked look through you build thread. Looks like y’all took your time and did it right. That was my problem when I first built this truck is I got in a hurry and didn’t do it the way I should have from the get go. Now 8 years later I’m changing a lot of stuff.
Old 03-16-2018, 01:07 PM   #9
StrokinRat
StrokinRat's Avatar
I finally got in touch with Porterbuilt and found out I have the wrong lower control arms for my set up. They are sending me the correct ones so that should take care of my problem, I hope.
