Old 03-02-2018, 11:10 AM   #1
cff
Active Member
51 GMC Engine Swap
Hi. I have a 51 GMC with a 228 in it. I was thinking of swapping in a 250 six cylinder. Will the 250 bolt right in? If not what do I have to do to fit it in? thanks, Ron.
cff is offline   Reply With Quote
Old 03-02-2018, 11:36 AM   #2
whitedog76
Re: 51 GMC Engine Swap
No, it will not swap right in.
The The pre-62 GMC Chevy's had a different bellhousing than the later 6's. Plus they mounted different.
Long story short... You would have to come up with some engine and trans mounts to make it work.
whitedog76 is offline   Reply With Quote
Old 03-03-2018, 08:20 AM   #3
Katrina/10
Katrina/10's Avatar
A 235 Chevrolet engine will bolt to the bellhousing, but you will have to fabricate a front mount.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-03-2018, 11:04 AM   #4
whitedog76
There’s a few options out there. The simplest is some side mount motor mounts and a trans crossmember.
Of course, you’ll need a transmission with the GM V8 style bellhousing.
You can cut and weld up your own engine mounts. Chassis Engineering used to have engine mounts, but since they’ve been bought by Heidt’s, I don’t know if their inventory is still available.
Jimenez Brothers have mounts for Chevy Sedans. Should be able to modify for trucks.
https://www.jimenezbroscustoms.net/p...g-kit-complete
