Old 11-04-2003, 10:02 PM   #1
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
<gulp> I hadn't thought of that possibility!
Those of you that followed this thread are aware that my 68 is currently down waiting on parts. Anyway, I was talking to my old man this evening and we ran through the symptoms again. He reminded me of a rather nasty possibility... a hole in a piston!
I'm keeping my fingers crossed, but only a compression test will tell for sure. In the mean time, I'm hunting down an HEI unit and a swap-on carb to eliminate those possibilities. Oh, man... that'd be just my luck!
But, that wouldn't explain A) the fact that it threw a very similar fit about a month ago then cleared itself out and B) the off-idle hesitation, would it? That's more like what a pissy carb would do, yeah? Jeez... I hope so!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 11-04-2003, 10:06 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Didn't you say you have a cold knock?
It could be the problem....fairl unlikley. SBC's (especially 327's) are usually very tough motors...the piston shouldn't break unless the engine was revved overly high......
I think your problems will proably be solved by an HEI, good carb, and a tuneup
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-04-2003, 10:22 PM   #3
shuttermutt
Cold knock (2-3 seconds on start-up), low power, poor gas mileage, low oil pressure at idle... it's all consistent, but (as far as I know) the engine hasn't been stressed that hard. I think I'm worrying too much. My wife laughs at me. While the truck is down, I'm "forced" to drive my BMW.
'Mutt
Old 11-04-2003, 11:05 PM   #4
truckster
truckster's Avatar
I think you'd notice a lot of blow-by with a hole in the piston. You'd probably have smoke and oil coming out of the motor everywhere.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-04-2003, 11:14 PM   #5
jamesi20
jamesi20's Avatar
Cold Knock,Lo Oil press.
I am concerned more than others about your problem!!! Low oil pressure and cold knock could very possibly be a Main Bearing problem.
jamesi20 is offline   Reply With Quote
Old 11-04-2003, 11:38 PM   #6
Class of 69
Class of 69's Avatar
The knocking, and low oil pressure are either a main, or rod bearing, OR, maybe a cam bearing...the ticking and missing and backfiring thru carb, are flat cam lobe symptoms. I suggest pulling the valve covers, and looking for a very loose rocker arm.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 11-04-2003, 11:42 PM   #7
jamesi20
jamesi20's Avatar
i AM INCLINED TO AGREE WITH cLASS OF 69..IT SOUNDS LIKE MORE THAN A CARB OR TUNE-UP PROBLEM.
Old 11-04-2003, 11:48 PM   #8
shuttermutt
Okay, maybe you guys don't understand the concept of making me feel better about this little problem!
What I want to hear is, "Oh, you forgot to change the <insert cheap part here>!" or "Ha! Just turn the <stupid little bolt> one-quarter of a turn!"
Oh, who am I kidding? I can see the writing on the wall and it spells R-E-B-U-I-L-D!
'Mutt
Old 11-04-2003, 11:53 PM   #9
cableguy0
actually you do not have to run a motor hard to put a hole in a piston running it lean will do the same thing. will burn a hole in a piston before you knew what happened
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-08-2003, 03:22 PM   #10
Class of 69
We'll be here to help you feel better when it comes time to pick a new cam!! Can you spell LOPE ??
