Patch Panel Help
Need some help - does anyone sell a patch panel to replace this part of the cab right where the floor meets the firewall on driver and passenger side?
Thanks ![]() |
Re: Patch Panel Help
I had the same issue with my apache,I made a piece from scratch for both sides,I welded the drivers side already but I didn’t weld passenger side yet,if I go back to shop I’ll take some pictures of the piece I made
Thanks thats what I was thinking as well...what gauge sheet metal did you use?
If I remember correctly 18 guage
Yeah mine's even worse. Was looking today at ecklers trucks. They have any and all patch panels available. So does lmc and others. Just Google c10 patch panels if you care. They are often cheaper to buy than build if you don't have the metal around and then fabricating them takes time. Unless it's a custom piece or super easy I just buy them now. For example you can buy an entire floor for our trucks for 550 +a lot for shipping. A local shop just did a 55 truck and I watched them do a new roof, new floor , rockers and fire wall So basically a new cab. Took them 3 day. Pretty wide aray of sizes too. You can go just do a piece to the. Firewall bend and or drive seat or from firewall front to back with different pieces. Check it out. Lots of fitting I am sure but a easy start. Ecklers are all 16 or 14 gauge. Good luck. Mine needs all cab supports , inner and outer rockers and both footwell. I am skinning doors to (95 bucks cheap) should have bought a better cab! Just spent 2k on new bedsides fenders and wood too! Ugh! Oh Well it's fun!
#6 | |
Here’s a few pictures of what I did,the pictures are taken from outside the cab(my cab is off the frame)I decided to take a little more rust out that’s why there’s 2 pieces,I bent the one end in my brake and the other side with an anvil and body hammer,hope this helps
Oh shoot sorry about that! Should have looked first
#10 | |
perhaps they are some page changing. you can always call them. it was working a while back and they did look good
ron |
![]() Join Date: Oct 2012
Or any other section. I just tried as well. I was really hoping I'd be able to see what they have, no one seems to make any floor sections that go far enough up towards the firewall.
#13 |
Yea - its a hidden area on the cab and relatively flat so I am going to just patch with some sheet metal and report back.
#14 | |
ron |
#15 |
![]() Join Date: Jan 2011
Jeff most of the inner rocker patch panels (looks like you need) will go up about 4 inches up and that will get most of what you need. The foot well patch will fix where it meets the side. For the little bits that are left you can use the drop from the other patch panels.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#16 |
I have the side kick panels, not an issue, looking for the floor piece but I will just use sheet metal
#17 |
#18 |
for the negative ones i did email them and the links are being repaired
ron |
#19 | |
#20 | |
here is the repaired link and 60-66 is on page 2 and 3 for those that need assistance http://directsheetmetal.com/Store/in...=index&cPath=2 ron |
#21 |
Thank you for following up. This is the left hand "toe board" and must be upside down. But for 60 bucks may be worth a shot.
EDIT; 40 BUCKS TO SHIP - NO CHANCE ![]() |
