Old 03-03-2018, 07:31 PM   #1
Hollow65
Hollow65's Avatar
Coolant temp sensor placement
I just installed my aluminum radiator and I have the probe style sensor. I’m not too thrilled about stabbing thought the fins of my new radiator. Is there another option? I can’t use the location on the heads because the headers. They melt everything in thier vicinity. Should I just suck it up and plunge it through the upper hose inlet? Thanks in advance.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 03-03-2018, 08:40 PM   #2
jayoldschool
Moderator
Re: Coolant temp sensor placement
Since you said headers (plural), I'll guess V8. If so, put it in the intake. However, if you use one of the head ports, the sensor and the wiring will be fine with protection.
jayoldschool is offline   Reply With Quote
Old 03-03-2018, 09:19 PM   #3
Hollow65
Hollow65's Avatar
I have a belt driven manifold, I’ll figure something out. Thanks for the reply.
Old 03-03-2018, 11:18 PM   #4
raidmagic
raidmagic's Avatar
Originally Posted by Hollow65 View Post
Attachment 1759033
Dude I completely forgot about the blower when we were talking about this earlier.
raidmagic is offline   Reply With Quote
Old 03-03-2018, 11:29 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
"I have a belt driven manifold".....love it!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-03-2018, 11:32 PM   #6
Mack B
Mack B's Avatar
Attachment 1759033
I can’t help, I just wanted to say how awesome that is!
Mack B is offline   Reply With Quote
Old 03-03-2018, 11:32 PM   #7
mongocanfly
Post Whore
some water pumps have a npt plug in them...does yours?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-06-2018, 01:45 AM   #8
luvbowties
luvbowties's Avatar
Question Re: Coolant temp sensor placement
Have you considered tee'ing it into the heater hose*(one flowing INTO heater core?) Seems like it should be at least approximately the same temp as that from radiator. To see how close, check both with infra-red temp tester.
Sam
........ ( http://forums.corral.net/forums/gene...-hose-%3D.html )
luvbowties is offline   Reply With Quote
Old 03-06-2018, 08:25 AM   #9
Hollow65
Hollow65's Avatar
Thanks for the reply’s, I’ll update this weekend. I have mad push on my job site so I’m working about 15 hours a day this week and have no time to tinker.. I’ll most likely go the water pump route. Thanks again.
Old 03-06-2018, 08:48 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
Isnt there a port in the head for a temp sensor? Pipe threads? I think there is.
Old 03-06-2018, 08:55 AM   #11
raidmagic
raidmagic's Avatar
He said he can't go that route.
Old 03-06-2018, 09:00 AM   #12
The Rocknrod
Moderator
I'd have to question that, maybe he doesn't "want to". I can buy that.
Old 03-06-2018, 07:51 PM   #13
jayoldschool
Moderator
You can go that route, you just need to insulate the sensor and the wiring. Coating those headers will help, too. My headers are coated, and I use an insulation sleeve on my temp sender. No melting, no burning.
Old 03-06-2018, 11:59 PM   #14
Hollow65
Hollow65's Avatar
Ding ding ding. Winner!
Old 03-07-2018, 12:00 AM   #15
Hollow65
Hollow65's Avatar
Headers are coated, they’re just from ‘97. I have a new set/style for my summer rebuild. I’m going to do the water pump tie in.
Old 03-07-2018, 01:55 PM   #16
vin63
It's Better With Nitro
vin63's Avatar
This is similar to what I've used in the past on some blown, street driven applications. I used to have to fabricate these myself, but it looks like there are cooling system vendors mass producing these now. This one is from Flexalite that splices into the upper radiator hose.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
