![]() Join Date: Feb 2014
Help identifying brake for drop spindles
Hey guys, I have a fiasco going on with trying to find out what brakes/suspension came on my chassis. I want to buy new calipers, rotors and pads but dont know what vehicle to search (figured out that they aren't 71-72's the hard way
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
Re: Help identifying brake for drop spindles
Rotors
![]() Join Date: Jul 2016
Rotors for 72
Which are the same for 73-8 or so and then some trucks had thinner rotors, your rotors are 1.25 nominal If the caliper hose bolt is metric then caliper from 79 or newer, if American then use the caliper for a 72 which is the same until they went metric in approx 79 |
![]() Join Date: Feb 2011
Hey Curt, I Google searched the caliper casting's & came up with 73-87 C10...hope that helps. They also fit some Cadillac's & Checker Cabs.
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#5 | ||
![]() Quote:
![]() ![]() Here was the issue with the 71 rotor and castle nut and cotter pin
#6 | |
This is the exact issue when you buy a kit. You have no idea what parts are from what.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#7 | |
I think you can take the spindle into a auto parts store and have them pull the ball joints for the various year ranges ( only like two ranges- 71-72, 73-87 ) and see which fits properly into it. That should pinpoint which spindle you have. Then you can probably assume you need the HD rotor, bearings, calipers and pads for that year range.
That's what I did. I order brake parts for a 1976 chevy 1/2 ton to fit my '67 as a result. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
