Good technique to re-center proportioning valve?
Problem: no brake fluid going to rear after installing a new CPP disc conversion kit. Front lines are fine.
Here is what CPP suggests: ![]() The dash brake light is on so I assume the differential valve is stuck, shutting off flow to the rear lines. I closed the rear bleeders and opened a front bleeder while gently depressing the brakes...no luck with the CPP approach. Maybe I'm reading it wrong though. Any suggestions on recentering the valve? I've read online of people using a small wire (or similar) to manually move the valve back to center.
1970 C-10 "Old Yeller" |
Post Whore
![]() ![]() Join Date: May 2015
Re: Good technique to re-center proportioning valve?
a small screwdriver will recenter it.....they also make a special little tool you can run in there to hold it centered while you bleed
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-04-2018 at 09:43 PM. |
Post Whore
here's the tool...https://www.speedwaymotors.com/Speed...RoCY-sQAvD_BwE
Thanks Mongo, I'll try this out. From the looks of it, I'm going to need a VERY tiny screwdriver. My prop valve is mounted horizontally so I can probably take a good picture of what you're talking about (for reference).
I tried to move the valve manually with a small jewelers screwdriver, but no luck. It got scratched up (it's brass of course), so before proceeding further I wanted to try and wrap my head around what I'm trying to accomplish...so bear with me.
As mentioned, the valve is mounted sideways, so taking pictures is fairly easy: ![]() With the brake wire removed: ![]() Looking straight into the brake light switch hole, it appears the valve is moved to the right (towards the firewall) and needs to be moved to the left (toward the grille) to be re-centered? I assume the brake light wire fits in the middle of the groove on the valve? My apologies in advance for the kindergarten-level illustrations.
I bled the fronts first. Then the rears. Then the fronts again and the prop valve reset itself without any help from me.
Post Whore
I can't tell from the pic which way it needs to move...but which ever way it needs to go you could try loosening a bleeder on that side and pump the brake...it "should" move by itself....
remove the rubber cap on the end of the valve .
there is a pin under there and needs to be held in place to hold the valve open . the port under the switch only works when the valve is pushed in from the end .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Try getting a buddy to help you. Do the CPP approach but instead of gently pressing the pedal, give it some good pumps and good hard hold on the last pump, then crack your front bleeders loose. If you think about it, in the operation of this thing in everyday circumstances, there will never be a slow, even, low pressure application of fluid to the valve that's gonna make it go over center. It's gonna be high pressure from your MC. Therefore give it some high pressure to nudge it back to where it belongs.
So I need to hold that pen open AND THEN try to move the valve over with a small screwdriver?
#11 | |
Grrr!!! This weekend I wasted a whole bottle of brake fluid trying to get this $#%& combination valve to re-center. I finally gave up and ordered another one on Ebay. For $40 it comes with the tool Mongo mentioned above.
It's sold by a pirate so it has to be good right? https://www.ebay.com/itm/161058469851
#13 |
Post Whore
haha....pirate jack.....what could possibly go wrong?.....haha
#14 |
#15 | |
#16 | |
holding the pin in with the tool or other means keeps you from having to play with the switch at all.
#17 |
Post Whore
RR..you'd be money ahead to get you one of the inexpensive brake bleeders...either vacuum or pressure.....it saves a lot of brake fluid....
#18 |
go to your local pharmacy and ask for a 2 oz syringe and about 2 feet of surgical tubing. draw fresh brake fluid into syringe, place the tubing over the bleed valve and force fluid BACKWARDS thru the system (from wheel cylinder to master cylinder). once you've done this with all 4 wheels, try to bleed again. lasts time i bought these two items it was less than $2.
p.s. remember to remove some fluid from MC before reverse bleeding. if not, you're gonna make a mess on the MC end ![]() |
#19 |
Update: received a new combination valve from Pirate Jack (you we’re right about the great service Willie). When I installed it the brake light went off, which I assume means that it’s centered. At that point I screwed in the special tool to hold it in place.
I tested it by disconnecting the rear line from the combination valve to see if fluid came out when pumped....nothing. Am I missing something? Or is it still not centered?
#20 |
Post Whore
have you checked your master to see if its pumping fluid? while you had the lines loose for the valve swap , fluid should have run out of the lines more than likely draining the reservoir...would have been a good time to rebleed the master
#21 |
Good point, I may be getting ahead of myself. I'll start with a bench bleed again and go from there.
#22 |
before removing the MC from the truck completely, remove the outgoing brake lines and plug the outgoing ports then see if you have a firm pedal. if so, then your MC is fine. if not, try the bench bleeding procedure again.
once you have established your MC is good, then bleed the FRONTS first, then the rears, then the FRONTS again. the prop valve needs to see pressure on the fronts before it will allow the rear circuit to open. |
#23 |
Thanks Willie, I did like you said and the pedal is firm. HERE’S a problem though; with all the lines off the MC, I’m getting NO fluid out the rear port. When I push the brakes I get plenty gushing out the front though. This is a brand new master cylinder too!
#24 |
Post Whore
sounds like you just found your problem....
#25 |
The saga continues...
Installed a new master cylinder and finally got fluid going back to the rear...almost. The rear rubber brake hose was clogged (why I didn't replace it along with the rest of the brake system I don't know), so I installed a new one. Now I finally got fluid to all four corners. Next is brake bleeding, and hopefully not another can of worms to open.
