Old 03-04-2018, 09:05 PM   #1
chrismoore701
chrismoore701's Avatar
New blower motor
Looking to get a new blower motor for my 79 stepside. Frame off show truck. I want to get an ac delco. Couple to choose from. The main two are with ac and without ac. Ac is like $100 where non ac is about $50. I have ac but not hooked up. What is the difference? Do i need the ac fan?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-06-2018, 08:37 AM   #2
chrismoore701
Re: New blower motor
It’s getting cold in here.
Chris
Old 03-06-2018, 09:07 AM   #3
zach_carver
zach_carver's Avatar
I think a/c blowers and a/c control head operate a little different. If you have a factory a/c system I would buy the correct one. Im not sure on the technical differences though
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 03-06-2018, 04:53 PM   #4
BHTH
I wonder if it has something to do with the fact that there is no off position for non-AC trucks, at least that is how it is on my 78. The fan always runs. I would think the blower motor itself wouldn't be different. I'll look at my wiring diagrams tonight and see if I can come up with something. It could be a physical difference based on space constraints. I would go with the AC one though in any case.
BHTH is offline   Reply With Quote
Old 03-06-2018, 05:12 PM   #5
BHTH
LMC truck shows the same part number for both for 79 for some cases There are some differences that have to do with vent hole diameter that could be the difference. Other than that, the difference is in the resistor block which is what I would expect. Also the FAN sizes are different is some cases.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=179
Old 03-06-2018, 06:04 PM   #6
Bandit130
Bandit130's Avatar
x2
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 03-06-2018, 07:57 PM   #7
chrismoore701
Isn’t the resistor block on the heater box?
Chris
Old 03-06-2018, 10:39 PM   #8
chrismoore701
Chris
Old 03-06-2018, 11:20 PM   #9
BHTH
It is out on the duct in the engine compartment with the blower motor. Oh and the wiring diagram doesn't show anything difference for AC vs non-AC.
Old 03-07-2018, 01:53 PM   #10
chrismoore701
I think i will pull the old one off. Take it down and compare.
Chris
Old 03-07-2018, 03:14 PM   #11
tucsonjwt
Have you checked Rock Auto? There are several different ACD blower motors available. The descriptions may help you. If you buy one there, remember to use their 5% discount code - google it to find the current code.
https://www.rockauto.com/en/catalog/...wer+motor,6916
tucsonjwt is offline   Reply With Quote
