Old 03-05-2018, 03:54 PM   #1
grubsster
grubsster's Avatar
LMC top fill fuel tank ?
Hi all,
I am buying an LMC top fill fuel tank from a person locally. I looked in the FAQ's and didn't' see any that were installed after the bed was installed.
Has anyone installed the LMC top fill with the bed on? If so what are the issues that you may have run in to? Any installation tips would be appreciated.
Thanks in advance.
grubsster is offline   Reply With Quote
Old 03-05-2018, 09:07 PM   #2
steven03
Re: LMC top fill fuel tank ?
Just did this not to long ago on my truck. Easy to install with the bed on the truck. fit up under the bed, mark where the hole in the floor needs to be drilled, drop tank/drill hole, fit up and mount, done!
steven03 is offline   Reply With Quote
Old 03-05-2018, 09:52 PM   #3
raidmagic
raidmagic's Avatar
Yep just did it with my truck. Think skinny when getting your arms in to put the hose connecting the filler neck and the filler. Otherwise pretty straight forward. Fits right in factory holes.
raidmagic is offline   Reply With Quote
