Old 03-07-2018, 08:06 AM   #1
rjs53
complete lowering suspension
Was wondering what some of you have done when lowering your truck? As far as buying kits or did you piece it together? I want to do the 5-7 drop, is there a kit that has everything? And new tie rod ends and disc brakes would be nice to do at the same time. When I search some kits have some of the stuff needed, others have more than what I need or the some of the same as others.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-07-2018, 02:14 PM   #2
HO455
Post Whore
HO455's Avatar
Re: complete lowering suspension
It depends on budget. Low buck searching for the cheapest components and piecing it together versus sending a check to someplace like Hotchkis for everything. Its about value and what you want out of the truck. So that being said what kind of budget do you have and how are you planning on using the truck?
RIP Bob Parks.
Old 03-07-2018, 02:45 PM   #3
demian5
demian5's Avatar
Rule of thumb for springs in front are no more than 3" drop. Rear up to 5" before C-notch needed.
http://www.classicperform.com/Chevy-Truck.htm#28
In front you could do 2.5" drop spindles too in front with a 2" spring but then you gotta run larger front wheel or possibly notch your lower control arms if sticking with 15".
For rear you could do 5" drop springs with a 2" block but will definitely need a C-notch. Going that low you will need the relocated panhard bar.
http://www.classicperform.com/Store/...ck/6572RDK.htm
http://www.classicperform.com/Store/...ck/6370BDK.htm
http://www.classicperform.com/Store/...k/6062DTBK.htm
I did 3" front and rear with a 1" block in rear with adjustable pan hard bar and rear shock relocation kit from CPP. nice complete kit with shocks.
http://www.classicperform.com/Store/...6372CSSK-D.htm
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-07-2018, 07:23 PM   #4
CC69Rat
CC69Rat's Avatar
As mentioned, going that low you need to consider 2.5" spindles then a 2" dropped spring up front. 5" coils, 2" drop blocks, shock relocation and adjustable panard bar in the rear. I have the same setup on my truck if you want to see how I put it together, it's a mixture of stuff some for the budget, some not so much. I converted mine to the 73-87 front kmember but if you're not planning on pulling the motor I wouldn't suggest that route. It just makes the truck drive better, centers the front wheels up in the fender well a little better, bigger brakes, different steering geometry, etc.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-07-2018, 09:35 PM   #5
rjs53
Budget, I would like to keep it under $2000. I did a C notch already and am going with a 20" wheel. I'm looking for something that has springs, shocks, drop spindles, adjustable panhard bar and all the hardware for relocating shocks or anything else that's affected by dropping it this far. What about pinion angle or the pitman arm? Does anyone make anything for that? Yes I'm going to put discs on the front. I noticed a lot of people are already going this route so I figure before I start buying a piece here and a piece there, maybe someone already has some info on it. As far as moving the cross member, I'm gonna leave that alone. I have a BBC and a small block, but it has a good running 350 in it. Definitely no power house, maybe 200hp, but I have a line on a 6.0 so will eventually go with an LS, just so I can cruise farther than the local cruise night without looking for a gas station.
2003 Dodge 2500
1969 C10
Old 03-08-2018, 01:56 PM   #6
original-71
///Relaxed Atmosphere
original-71's Avatar
www.earlyclassic.com
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 03-08-2018, 04:43 PM   #7
demian5
demian5's Avatar
Originally Posted by rjs53 View Post
Budget, I would like to keep it under $2000. I'm looking for something that has springs, shocks, drop spindles, adjustable panhard bar and all the hardware for relocating shocks or anything else that's affected by dropping it this far.
Dude click my links, you can get it done for about $800.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-08-2018, 04:48 PM   #8
rjs53
Checked your links, pretty much what I’m looking for.
Just making sure I’m not missing anything. Thanks for the help
2003 Dodge 2500
1969 C10
Old 03-08-2018, 04:53 PM   #9
demian5
demian5's Avatar
Only issue I see is that you have a 69 with drum brakes and would need to convert to disc along with the lowered spindles...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-08-2018, 09:05 PM   #10
rjs53
Plan on going to disc brake and drop spindles. The early classics says wheel actually moves in so no problem with rubbing. I am trying to get an answer out of cop about their spindles. Your center link is a great looking kit with spindles.
2003 Dodge 2500
1969 C10
Old 03-16-2018, 10:39 PM   #11
rjs53
Got the early classics 4-6 drop. I thought I would order the brakes this week, but didn't think weather or not they had a disc brake kit that doesn't include spindles. Has anyone found a disc brake conversion for drop spindles, as the kit I ordered comes with the spindles
2003 Dodge 2500
1969 C10
