03-07-2018, 10:55 AM | #1 |
bronze king pin bushings
what are your guys thoughts on bronze king pin bushings are they worth the money?
Brian |
03-07-2018, 11:23 AM | #2 |
Re: bronze king pin bushings
Are you talking about a king pin D60 or converting the closed knuckle 44?
03-07-2018, 11:44 AM | #3 |
I think he is talking about the bronze bushings made by Reid Racing.
https://reidracing.biz/products/dana...gpin-bushings/ Haven't used them my self, but I'm thinking if you keep them in fresh grease there is no reason why they shouldn't be worth it. Don't have to worry about them cracking in half, especially if you have a really large tire you're going to bolt on |
03-07-2018, 12:13 PM | #4 |
fit the knuckle hole much tighter than factory style . lot less flex over stock style . last much longer with little to no wear . work better with big tires .
and there is other brands listed on ebay all the time for much less than reid prices .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-07-2018, 01:11 PM | #5 |
Gotcha Kwmech, on a D60 I'd do it if I were into the knuckles. On a closed knuckle I'd keep the tapered bearings, when they're in good condition you almost don't need power steering.
03-07-2018, 01:21 PM | #6 |
I just put in new bushings and springs. The nylon bushings did not look too bad, which I found odd. But the springs on both sides were sagging. One side of each spring on each side sagged 1/8" and 1/4" strong on the worst side; when compared to the new springs. They looked like a banana shape. I picked up a couple degrees positive camber off new springs and bushings.
I would put the money towards first: selectable locker, upgraded axles, with 35 spline outers, yukon locking hubs. Unless your racing and doing the whole enchilada. Oh and PICS! We need PICS! Another two cents.... worth the price paid! j
White K20 |
