03-07-2018, 11:19 AM | #1 |
P30 chevy car hauler
have 1980 P30 turning into car hauler 454 engine w/400 turbo thinking of changing to 700r4 or adding gear vendors overdrive. Ideas on which would be better?
03-07-2018, 11:36 AM | #2 | |
Re: P30 chevy car hauler
A 700R4 would be a poor choice in anything that weighs more than 7,500 pounds. A TH400 with 3.73 or 4.10 would be able to cruise at 60-65 all day long. 4.56 + would be another story. |
03-07-2018, 12:03 PM | #3 |
no to the 700-r4 in that weight class.
if over drive go 4l80-e or gear vendors . gear vendor is 0.78:1 and no lockup drop of 200ish rpm and cooler running trans . 4l80-e is 0.75:1 and has lockup for more rpm drop and cooler running trans from no slipping hence lockup . 4l80-e has same gear ratios as th400 but overdrive gear and convertor lockup to drop rpms by around 800ish at highway speed. if 4l80-e check these guys out . www.usshift.com for stand alone controler . and play with this for your rpm's at a given mph . http://www.grimmjeeper.com/gears.html rpm's @ 70mph with 215/85/16 common size in the 80's 3.73 = 3050 4.10 = 3353 4.56 = 3729 if 4l80-e overdrive locked up installed gets you . remember these #'s drop back to above if pulled out of 4th overdrive gear . minus around 200rpm for lockup . 3.73 = 2165 4.10 = 2380 4.56 = 2647 remember tho you need to hit your middle power band of the engine at cruising speeds so the engine is not bogged down to much and has room to climb before top out of torque curve falls off. so lowest is not always best in a work truck hauler . you might even wana go deeper than 4.56 if you run overdrive so it gives you a big power advantage like a longer pry bar .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 03-07-2018 at 12:10 PM. |
03-07-2018, 12:35 PM | #4 |
I tried a nicely built 700r4 for towing behind a 454, it didn't last long. Not recommended.
I like the TH400, I wish I would have kept it instead of doing the 700r4 swap. In the end, I went to an NV4500 and never looked back. Awesome trans for towing with a big block.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
03-07-2018, 02:20 PM | #5 |
I've considered a gear vendors many times, but given the super high price it sells for and the fact that after all that you still don't get a lock up converter, they are simply not worth the money.
Keep the Turbo 400 and deal with high cruise RPM's, or get a 4L80E and a shift computer.
1977 GMC Sierra Grande |
03-08-2018, 10:56 AM | #6 |
Out of curiousity, what is the GVW of your P30? Most are 10,000. By the time you but a cab and bed on, you'll be around 7500-8000 pounds(more if you are using a moving bed). That doesnt leave much weight for a car on the back.
03-09-2018, 03:16 PM | #7 |
1981 Chevy C30 440 Holmes 42K one owner miles |
