Old 03-07-2018, 07:43 PM   #1
IdahoC10
IdahoC10's Avatar
Ride Height and Tire Size Help
Hi guys! I am looking for some help with ride height and tire size on my 64 C10 short bed stepside. I have included a couple of pictures of the look I am going for.
I am thinking of using a little larger tire than what many seem to use (30-32” tall and 10.4-10.8” wide) if they will fit well. But very open to experienced opinions of course!
I really like the way the green truck is setup (with a little more sidewall). Any idea what the tire height is and how much, if any, the front and rear has been lowered? I was thinking that maybe a 31.5” tire with 2” lowering spindles and 2” lowering springs in the rear may get me close?
My truck will is COMPLETELY torn apart right now so I can’t do any measurements.
Thanks for your help.
IdahoC10 is offline   Reply With Quote
Old 03-07-2018, 08:27 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Ride Height and Tire Size Help
The green truck has 20” wheels likely. The bottom truck appears like 15” tires with 275/60’s on it.
The larger wheels usually don’t have that much sidewall on them as the smaller 15” tires do and yet still are 28-29” tall
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-07-2018, 08:54 PM   #3
IdahoC10
IdahoC10's Avatar
Thanks for the reply. The most difficult part for me is determining the suspension height and tire diameter. Any idea if the ride height of the green truck if that is a 28-29” tire?
Old 03-07-2018, 09:01 PM   #4
PGSigns
PGSigns's Avatar
That green truck in the pictures has not been lowered much. You may find on the tire size you are thinking you are not going to get but so low. All depends on what the final goal is for your truck. I run a 28" tall tire front and back and a 4 1/2"/6" drop and the tires are up there pretty good.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-07-2018, 09:20 PM   #5
Clyde65
Clyde65's Avatar
Here is mine.
4” front drop, 5” rear
295/60/15 rear
235/70/15 front
Clyde65
Rebuild of Clyde
support our troops!
Old 03-08-2018, 12:16 AM   #6
Cooper197
Cooper197's Avatar
I really need to take some better pics of mine, but here's what I've got.
2.5" drop spindles in the front and 3" drop springs in the back.
Front is 235/50R18 - 27.3"
Rear is 255/45R20 - 29"
Front is a good fit. There's plenty of room to be at full lock and have suspension fully compressed without hitting. In the back, the full tire is tucked in the fender and about 1/4 inch of the wheel is tucked as well. Again no issues with fitment in the back, even with suspension fully compressed.
Cooper197 is offline   Reply With Quote
Old 03-08-2018, 12:22 AM   #7
rvrfoot
rvrfoot is offline   Reply With Quote
Old 03-08-2018, 12:46 AM   #8
Captainfab
60-66 Nut
Welcome to another Idahoan
Keep in mind that the stepsides have less room width wise on the rear to tuck a tire. The gray truck I would say is mostly stock suspension height and I agree on the tires likely being 275/60R15's. Do you have a particular wheel in mind?
Old 03-08-2018, 01:15 AM   #9
IdahoC10
IdahoC10's Avatar
Thanks for the pics and info guys. It has been helpful. I am going to look at the pics a little closer with your specs and see how that compares with what I was thinking. It looks like I am going to be on the smaller side for good fittment.
rvrfoot: what are your lowering specs and tire diameter?
Captainfab- you are in the better part of the state. I grew up in Moscow and living near Boise now.
These are the wheels that I am looking at, probably in an 18”. I think they are available in 8” and 8.5” width with about 4 or 4.5” backspacing. Need to double check.
Old 03-08-2018, 01:18 AM   #10
IdahoC10
IdahoC10's Avatar
This is what it looks like right now.
Old 03-08-2018, 01:20 AM   #11
rvrfoot
Old 03-08-2018, 01:22 AM   #12
rvrfoot
Rear is 5in coil 1 1/2 block. Front 2in coil 2 1/2 drop spindle.
Old 03-08-2018, 01:23 AM   #13
rvrfoot
I will check on the tire size this weekend.
Old 03-12-2018, 11:42 PM   #14
IdahoC10
IdahoC10's Avatar
After thinking about it more I can see how a little smaller tire may fit better. Would a 275/55/18 (29.9x10.8) with 2.5" drop spindles and 3" rear lowering springs get me ballpark close, or would stock height be better for a tire of that size?
Are 275s on a 8" to 8.5" wide wheel too wide for a stepside?
Old 03-13-2018, 07:54 AM   #15
raidmagic
raidmagic's Avatar
Here is mine.
295/60/15 rear
235/70/15 front
That is pretty much what I'm looking to do. What rims are those?
raidmagic is offline   Reply With Quote
