Old 03-08-2018, 04:15 AM   #1
yeah_yeah_na
235 cu dizzy wobble
I have just imported a 60 longbed stepside into NZ from LA. It arrived a couple of weeks ago.
When I first started it I noticed the dizzy wobbled in the block, it runs what appears on the face of it to be a factory dizzy, I've pulled that and can't see any signs of wear, the guy I purchased the truck off tells me its a new repro 235 cu engine block. I have not run the numbers to check this out but I was wondering if anyone else has had this issue? The truck runs fine at 60mph but I do notice a little pre ignition knock at low speed, not under load, the opposite to what you'd expect . I am using the truck as everyday transport, its my only transport, so I'd like to repair it.
yeah_yeah_na is offline   Reply With Quote
Old 03-08-2018, 10:19 AM   #2
TheBrewery
TheBrewery's Avatar
Re: 235 cu dizzy wobble
What's a "dizzy wobble"?
Mike
1960 C10 Short Step 235 w/ 3 on the tree
1999 Mazda Miata <- Track Car
2016 Chevrolet Colorado z71
2016 Chevrolet Traverse - Wifes Car
2014 Honda CBR500R <- Also A Dust Collector
2009 Suzuki GSXR600 <- Stolen
TheBrewery is offline   Reply With Quote
Old 03-08-2018, 10:39 AM   #3
andyh1956
You should know that the 235 has what's called a "Floating Distributor". That means the Vacuum Advance pulls the whole distributor around to advance the timing, unlike the next generation that just moves the Breaker Plate where the Points / Condenser mount. You MAY have seen the Distributor Advancing / Retarding.
andyh1956 is offline   Reply With Quote
Old 03-08-2018, 10:43 AM   #4
urmyboyblue
I think that is a sign you have vertigo.
urmyboyblue is offline   Reply With Quote
Old 03-08-2018, 11:01 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Ya it's a medical term, it's all very technical.
Old 03-08-2018, 11:41 AM   #6
yeah_yeah_na
Thanks, I noticed that also, this issue is more like the distributor has a universal where it enters the block, should there be a bush in the block at the base of the distributor where the drive is supporting it?
Old 03-08-2018, 11:49 AM   #7
yeah_yeah_na
Its very common down here at the bottom of the world!
Old 03-08-2018, 12:19 PM   #8
shp4man
shp4man's Avatar
They make a repro 235 engine block?
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 03-08-2018, 12:22 PM   #9
oem4me
My '62 C20 also has the 235 six, and the distributor head wobbles around too. Despite that issue, it has always run flawlessly like a sewing machine. Yes, it's contrary to common sense that it could be damaged or worn out and run well at the same time, so I've wondered about it as long as i've owned it. I've thought about swapping it out many times, but you know the saying, "if it aint broke... why fix it?"
Old 03-08-2018, 01:41 PM   #10
shp4man
shp4man's Avatar
The thing about a points type distributor that will cause driveability issues is wear in the distributor shaft. If the points cam wobbles back and forth, the dwell changes at random. Not good.
Old 03-09-2018, 02:44 AM   #11
yeah_yeah_na
Great point! I've only had the truck less than a month but it starts and runs great so far. I'll leave it until it creates a problem, there's a few other jobs on the list before for I add to it.
