AD Cab Dimensions
I have done a lot of searching to no avail...I am back on my 1950 chevy pickup after a few years of being away from it. I have gained a massive amount of knowledge since I did the cab rust repair, as I have been employed by an old school panel beater for two years now. Looking back on some of my sheet metal work i see a lot of things that are very amatuer and frankly just not good...Im sure im not the only one that has experienced this scenario lol...I had never fully welded the door pillar to the inner rocker and still hadnt installed the outer cowl panels. First thing i did after re approaching the project, was rebuild my hinges and hang the doors as this had not been done since the rust repair. I did brace between the front and rear pillar but did not properly cross brace or take measurements before cutting it all apart. As I had come to guess, my door alignment is way off. I am going to have to cut it back loose and redo some things to get the doors to fit peoperly.. the reason I am posting is to see if there is another post that someone can lead me to, that has some detailed cab dimensions especially in the door opening, or if someone is willing to take some measurements for me... I am not afraid to cut it back loose and now have the knowledge to do things right, but would love to have some measurements to reference. Height from floor to top of door opening for the front and back. Distance across door opening top and bottom, things like that. Any help from you guys would be greatly appreciated.
Thanks, Andy |
Re: AD Cab Dimensions
The 47-54 Chevy assembly manual has alot of dimensions in it. Unfortunately it's rather hard to read/decipher.
I found these pictures here. http://chevy.oldcarmanualproject.com/ |
Post Whore
![]() ![]() Join Date: May 2015
could you not just measure your doors to get what you need....after all the doors are what you've got to make fit in the hole anyway..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-09-2018 at 02:36 PM. |
Not only that but these trucks weren't very consistent! My drivers door is about a quarter inch shorter at the body line than the passenger door!
You need to use the doors to make the cab fit them. DO NOT make the cab fit the measurements and then expect the door to fit. This isn't a 2015 Lexus. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#5 | |
Even the door that fit perfect on a donor truck may not fit right on another cab when you go to install it. My experience that isn't all good but is 45 years worth on these is that you fit the doors right then build around that rather than build then try to get the doors to fit. The assembly manual is well worth the 30 something dollar investment for putting the cab together. The other issue we run into on these trucks is that they were made in several plants around the country and the stamping dies may not have been the same or at the end of the run may have been worn a bit. Meaning that parts from one plant may or may not fit up with parts from another plant.
I should add one thing. make sure that you cab is on a square and level surface icluding having the frame sitting level on stands to square things up. It is something that we don't often think about but if the shop floor or work area isn't perfectly level to begin with and the cab isn't perfectly square and level the end product won't be square and straight.
I second that mr48. add to it that in order to get the cab right it needs to have a good set of mounts under it and be bolted down properly like it would be normally.
#8 | |
Brian
