Old 11-08-2003, 12:07 AM   #1
72MARIO
72MARIO's Avatar
Help with Van Tilt Needed
I picked a Van tilt up for 30 dollars yesterday. I was wondering how hard are they to make fit ? Can I just cut the wire's and put the original plug from my 72 on the van coloum ? The tilt coloum from the van is missing the gear pointer and fiber optic light does anyone know where to get a new one ? Oh and one last thing the bearing seemes loose. Can I get a new one at Gm ?
Thanks's.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-08-2003, 01:06 AM   #2
Solver
Solver's Avatar
Gm (delco) still makes a adapter harness to go from van tilt flat to 68-72 round plug.Part #1894851 it's about $6-$7. Some of the venders on this board and LMC sell the tilt pointer for about $6.
I don't think there is a fiber optic on van tilts I think it is bulb lighted but I could be wrong on that.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 11-08-2003, 08:44 AM   #3
JimKshortstep4x4
Talking
The van tilt uses a bulb and the single gray wire that is along side the TS wires should be hooked up to the dash lights. The vendors will have the bearings.
Here is a site link for installing help. Click on tech articles.
Jim
http://www.geocities.com/sshevnock/home.html
Old 11-08-2003, 12:22 PM   #4
72MARIO
72MARIO's Avatar
Thanks,
So the van tilt has a bulb for the shift pointer ? and I run the grey wire to the back of the gauge cluster ?
2005 TAHOE DD
Old 11-08-2003, 01:32 PM   #5
kaycee
kaycee's Avatar
The van tilt has a bulb andd you will allso need to put the N.S.W.(Neutral Safety Switch)farther down the colum .This is pretty easy you need to decide which switch u want to use the van is alittle different as to how it hooks to the colum for your reverse light's.You basically need to make the same window as it is originally just a little farther down the colum.Hope I helped and not totally confused u
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 11-09-2003, 01:17 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally posted by 72MARIO
Thanks,
No...on your fuse box there is a male terminal labled lights...or something like that. It is only powered when you turn on the parking lights or headlights. Plug it into that terminal.
