03-11-2018, 01:42 AM | #1 |
Guess what this hole was for
Been lurking for years, started a truck 69 gmc longbed and had to sell it, and finally got a new one 70 c10.
I keep wanting to start a build log, just haven't gotten around to it. I will. As many of you have seen numerous "modifications" over the years, I wanted to ask your help. Can anyone identify what this hole was created for? That's between the driver's side door and the instrument cluster.
"I'm rooting for you, and remember, were all in this together." ~ RED GREEN 1970 Chevy Custom. |
03-11-2018, 01:55 AM | #2 |
Re: Guess what this hole was for
I have a similar hole or holes in the same location on my 70 c30. Maybe it was a trend back then to lock a chimpanzee in the cab with a cordless drill.
03-11-2018, 02:08 AM | #3 |
I agree. This one had been dropped, without changing the original ball joints or shocks. Lol. It does seem to be a 2 owner vehicle tho.
03-11-2018, 02:12 AM | #4 |
Scrapper 1
could it had been for a spot light.If you have a bigger pic pf where it is it would help
03-11-2018, 02:35 AM | #5 |
Here is a larger area of the hole.
The corresponding hole on the outside cowl. Note the amazing handiwork. And the strange grommet I found on the roof, filled with Bondo as well. I assume this corresponds to the cb radio mount holes under the lip of the dash.
03-11-2018, 02:43 AM | #6 |
My C30 had emergency lights mounted on the roof at one time so the were several roof holes also.
03-11-2018, 02:50 AM | #7 |
This one only has one grommet, center of the roof. But it came power steering, brakes, tinted windows, a/c , heavy duty suspension, so a spotlight wouldn't surprise me.
03-11-2018, 10:44 AM | #8 |
That dash to pillar hole was definitely a spot light.
Maybe the roof was also. Mine had a roof mounted spot when I bought it back in 89. Get that hole sealed up or you will end up needing a new roof/cab. Ask me how I know...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-11-2018, 11:17 AM | #9 |
Clay68c10- Never seen a roof mounted spotlight. But, I wish they were both still there, guess it's just two more things to keep a look out for at the junkyard.
03-11-2018, 12:50 PM | #10 |
Maybe it was some type of rescue or emergency truck in the past?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
03-11-2018, 01:44 PM | #11 |
@ klb. Who knows?
There is an inner hole to match the roof hole as well. Time to collect pictures, and start searching for parts. If I can find em, I'll put them back on. Thanks for your help!
03-11-2018, 02:03 PM | #12 |
That is my first guess also....
1970 C10 Short Stepper with 71/72 front clip. |
03-11-2018, 03:20 PM | #13 | |
It could also have been an antenna maybe, although that seems like an extreme measure to cut a hole for an antenna! -klb
03-11-2018, 05:16 PM | #14 | |
There are no real marks on the door jamb, but I would think a roof rack type accessory would not need a hole drilled as well. But your right, that would be overkill for an antenna. It seems no one takes pictures of the interior roof of the cab.
03-11-2018, 06:17 PM | #15 |
It could have also been a siren or megaphone.
Checkout this thread of ambulances: http://67-72chevytrucks.com/vboard/s...d.php?t=403359 -klb
03-11-2018, 06:45 PM | #16 |
Couple more threads with some interesting bits of info:
http://67-72chevytrucks.com/vboard/s...=siren+install http://67-72chevytrucks.com/vboard/s...=siren+install http://67-72chevytrucks.com/vboard/s...ghlight=rescue -klb
