03-11-2018, 05:10 PM | #1 |
re-shooting base help!!
hey there guys,
I'm re-shooting my base coat. I'm not happy with the tiger stripes and have knocked everything down to at least 800 grit. I had already cleared. The more I wet sanded to get rid of the orange peel, the more I noticed my coverage sucked!!!.......Rookie Painter I most add!!!! Questions is: Is 800 too fine for BITE for my re-base? or do I need 600? It is a metallic blue, 506 Medium Blue Poly
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
03-11-2018, 05:14 PM | #2 |
Re: re-shooting base help!!
What paint are you using? The spec sheet should say what grit is recommended.
03-11-2018, 05:40 PM | #3 |
I'm no a pro painter but have sprayed about 5 trucks now. Each time learned a little more and long way to go to be called a car painter.
Metallics are very difficult and really tough for a newbie. I had a similar problem with tiger strips on a '92 gmc I restored. Watch YouTube vids on spraying Metallics. Good info out there. Gun set up plays a huge role in success. The last metallic I shot i did normal 50 percent overlap and then on last coat pulled gun back and did a dusting type coat directly after wet coat 3 coats base Good luck. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 03-11-2018 at 06:41 PM. |
03-11-2018, 06:01 PM | #4 |
Post Whore
You might try reposting this in the paint and body work section.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-11-2018, 06:12 PM | #5 | |
Doing a drop coat on your final coat of base is probably the easiest way to not repeat your tiger striping. |
03-11-2018, 06:42 PM | #6 | |
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
03-11-2018, 06:52 PM | #7 |
32 years exp with body shop here, 800 will be fine. Good luck and happy sanding
03-11-2018, 07:02 PM | #8 |
Who Changed This?
If the stripes are caused by the "metallics" falling out of solution, keep shaking the gun or rent a paint pot that will stir the paint constantly. This used to be true when aluminum was the additive. I had a '64 Malibu SS that was silver, and that ensured that the paint was consistent. I don't know if this is true for newer paint.
03-11-2018, 09:43 PM | #9 |
Nason...I looked at the tech sheet, nothing mentioned about "recoat" sanding
03-11-2018, 09:46 PM | #10 | |
I rushed also....shoould have checked my stuff prior to clearing. F.N.G. hahaha
03-11-2018, 09:58 PM | #11 |
yes sir..... Mr. Jim replied... he's the one I was hoping would chime in ; thank you tough for your reply!!!
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" Last edited by stevenfromtexas; 03-11-2018 at 10:47 PM. |
03-11-2018, 10:01 PM | #12 |
thank you Mr. Jim......
03-11-2018, 10:09 PM | #13 | |
It was a rookie painter/lack of experience issue actually. thank you for your reply...... i'm going to spray again tomorrow. Hugger and 60_project mentioned 800 being ok.... I'm going to watch my coverage and obviously make sure there is not striping this "second" go-round.
03-11-2018, 10:18 PM | #14 | |
03-11-2018, 10:23 PM | #15 | |
Get some darn good lighting on it. Side lighting especially. The last metallic I sprayed was on corolla flip, hood. Saw some stripping so I sprayed one base coat in on direction and the other coat opposite in a cross pattern Prob not the way a pro would do it but results where good. Mark
03-11-2018, 10:36 PM | #16 | |
was wet sanding and "admiring" my work and stood back and thought, " what the crap"!???!! but with non "PC" words.... Lighting is a problem I will address also....thank you for that too.....The lights in my garage are not sufficient. Thank you Mark!!
03-11-2018, 10:53 PM | #17 | |
03-11-2018, 11:09 PM | #18 | |
guess there's not better way to learn the hard stuff than to start with the hard stuff....hahahahaha
03-12-2018, 08:48 PM | #19 |
re-shot everything today. turned out much, much better. thank you guys for your help. the clear flowed a lot better too, that was a mixing issue. there shouldn't be as much sanding this time.
sorry no pictures....it actually looks the same, just better coverage and no tiger stripes
03-12-2018, 09:58 PM | #20 |
Good news!
03-12-2018, 10:00 PM | #21 |
03-12-2018, 10:09 PM | #22 |
I have a radical idea!
All your hard work will be a worth it. That's a beautiful factory color.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-12-2018, 10:15 PM | #23 |
thank you brother!!! I was looking at your rides earlier in the "drive way" thread. I LOVE your red '69 in post #319!!! rally's are my favorite!!!
03-12-2018, 10:37 PM | #24 | |
I'm guessing you know all of this but if not it may help. Don't wait too long to wet sand. Easier to sand before it gets too hardened. I think I sanded my Nason select clear in 48 hours. 2000 grit with soapy water. Soak the paper for a few minutes first. Want sandpaper soft and not sharp edges. I used 3m perfect it kit. 3 step process that has really good results.
03-13-2018, 06:41 AM | #25 |
Glad things went better for you. It would suck to do all that work and then have to live with a not so nice paint job.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
