Old 03-11-2018, 08:45 PM   #1
tuffss
tuffss's Avatar
73 C10 big block frame mounts
Hi Guys.
Im after BIG BLOCK CHEV frame mounts and clam shells for a 73 C10, truck is currently a small block truck but doesn't seem anyone is reproducing BBC frame mounts for 73 onwards, plenty for anything upto 1972 but what about 73 trucks, other than scouring ebay etc does anyone have any or know where they can be purchased.
Cheers guys.
tuffss is offline   Reply With Quote
Old 03-11-2018, 09:48 PM   #2
KrazyRay
KrazyRay's Avatar
Re: 73 C10 big block frame mounts
You need 1/2 ton frame mounts and use the big block clams and clam shells. The mounts have several different holes to accept big block or small block clams.
KrazyRay is offline   Reply With Quote
Old 03-11-2018, 10:09 PM   #3
tuffss
tuffss's Avatar
Thanks for the response but is there anyone you know doing reproduction of these items, seems plenty for earlier trucks just not for 73 onwards.
Cheers.
Old 03-11-2018, 11:31 PM   #4
KrazyRay
KrazyRay's Avatar
There are no repops that I know about. Getting an original 1/2 ton big block setup is hard to find. You can start by getting 1/2 ton frame mounts. You might be able to find new big block motor mounts. They should be the same for 1/2 and 3/4 ton. The clam shells all bolt up to all of the engines, but there are different profiles on the distance of the long bolt from the base of the clam shell.
Old 03-12-2018, 02:29 AM   #5
Titomars
Titomars's Avatar
The frame side brackets are the same for the SB and BB. Part numbers are the same for C/10's which is 464709 for the LH. and 464710 for the RH.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-12-2018, 06:34 AM   #6
tuffss
tuffss's Avatar
Appreciate your response, so frame mounts are the same for BBC and SBC, don't mean to doubt you but are you 100% sure about that ?, that's gonna make the process a lot easier for me.
Just means I have to find clam shells if that's correct.
Cheers
Old 03-12-2018, 07:23 AM   #7
75C10
It's been ten years or so but I am pretty sure that I just used the small block mounts to install my 454 in a 75 c10.
75C10 is offline   Reply With Quote
Old 03-12-2018, 10:41 AM   #8
cruizin01
Are you talking about the brackets from the subframe to the top of the frame? I used everything from a c10 on my 2wd conversion and my big block engine mounts bolted right in with no issues.
cruizin01 is offline   Reply With Quote
Old 03-12-2018, 10:51 AM   #9
Titomars
Titomars's Avatar
Cheers
100% sure. 20+ years with GM dealers starting in 79 and I confirmed it last night in my GM 73-78 parts catalog. As long as you are comparing C10 to C10. C20's and C30's use a different number which are also the same for SB and BB. K series use another number but since the 454 was not offered in a K10 there is no comparison.
Old 03-12-2018, 11:10 AM   #10
100%Chevy
I used 1/2 ton small block mounts to put a 454 in my 82 K-10.
They will work but the big block fuel pump hits the crossmember.So,I used a shorter fuel pump from a 60's Chevy big block engine.It works but has no return line.
The big block clam shells are about 3/8"+/- higher than the small block shells.
I have the correct pieces but haven't put them in yet.
The big block shells are easy to find in old motorhomes.
Mike.
100%Chevy is offline   Reply With Quote
Old 03-12-2018, 06:41 PM   #11
v30crewcab
v30crewcab's Avatar
6.2 diesel clamshells are the same as big block also.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-13-2018, 12:05 AM   #12
tuffss
tuffss's Avatar
Thanks so much guys, really appreciate the input.
Cheers
Mick
Old 03-13-2018, 12:58 AM   #13
tuffss
tuffss's Avatar
Really appreciate your input regards the frame mounts, good to know I can use my existing frame mounts.
Could I trouble you to let me know what the part number is for the Big Block Clam shell in your parts catalogue to suit 73-74 C10, might be easier to source having a part/no.
Thanks again
Mick
Old 03-13-2018, 08:32 AM   #14
HunterRotten
HunterRotten's Avatar
I've just got the big block in my truck this past weekend and we used the same motor mounts that were used on my small block, and clam shells too. I don't know enough to confirm this but theyre probably the original ones for the i6. They matched the rest of the trucks frame condition. (Can't confirm this, just my suspicion.) If anyone wants to educate me on that, please do.
It was a tight fit, even without fenders or core support on the truck but it went in there and it went in there like butter. The bolt fell into the clam and motor mounts no hammer or adjusting needed. Haven't gone any further than that to see if there are any issues. I don't have a mechanical fuel pump like someone stated before.
hope I could be of any help, maybe I'm just confusing everyone further. thanks
HunterRotten is offline   Reply With Quote
Old 03-13-2018, 09:40 AM   #15
KrazyRay
KrazyRay's Avatar
The I6 frame mounts are the same as V8.
It is correct. You need the taller profile clam shells for big block 4wd applications for the fuel pump to clear. The 2wd big block clam shells have a shorter profile than the 4wd.
Old 03-13-2018, 12:16 PM   #16
HunterRotten
Thanks Ray, that simple explanation cleared up a lot of the confusion I was getting from the rest of this thread. Hopefully it helps other people make some sense of it too.
Old 03-14-2018, 08:32 PM   #17
Titomars
Titomars's Avatar
Thanks again
Mick
73 to 78 all C10 to C30 BBC mount assembly 357717, 2 required. Note: these are discontinued by GM
Old 03-16-2018, 10:23 AM   #18
Sik66
https://www.ifabspeed.com/product-pa...mount-brackets
Sik66 is offline   Reply With Quote
