1957 front fender / rocker not lining up?
Hey guys, I bought a 57 truck a while back but it was in pieces, I'm trying to get it back together and my front fender are not lining up on the bottom with the bottom of the step. From what I can tell I'm guessing they should be close? The bottom of my front fender seems to sit about 3/4 maybe an inch below the bottom of the door and step to get into the truck. Can anyone show me some good pictures of theirs?
Re: 1957 front fender / rocker not lining up?
Don't know about 57 but on 59 the bottom of the fender and door/step sill do not line. Mine is off about 1/4", I focused on getting the top and horizontal crease lined up with the door and cab cowl.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
these old trucks were almost a custom build from the factory, by that I mean they are all different so a fender from this truck may not fit that truck. or a door etc. is the fender/door the stock unit from the truck? the door should be adjusted in the opening first, with the cab bolted down on the frame, then the fender set on after that and lined up with body line and cowl etc. after that check the rocker alignment. you may need to try a different fender or door.
was the rocker/step replaced? maybe not quite right? was the truck ever repaired in that area? does the dimension from ground to bottom of rocker look the same on both sides? |
When I lineup the top and the cowl I'm off on the bottom. From what I was told all the parts are original to the truck. It doesn't look there was damage to the step or front end of the truck. I haven't had a chance to get the passenger side on yet to check it. They do measure the same from side to side. I'm going to try to get some pics to post.
pics would help for sure.
check the contour of the rockers because sometimes they get crushed upwards into the door opening so they would be "shorter" that they should be. snap a pic install and adjust the door to the opening and snap a pic of the rocker to door relationship install the fender and line up the body line of the door and the fender. snap a pic of how the fender fits compared to the cowl and rocker grab a pic of the dimension from the body line to the lower edge of the fender, I can compare with mine if you want.(57 gmc). all the cabs should be the same. the difference in years is the front fenders are longer on the 58-9. (ok, there are other things too but for this scenario....) |
#6 | |
My 55 2nd is as the Counts, driver side 1/4 in low, and passenger side lines up perfect. My truck appears to be as it was from the factory, never wrecked
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
still waiting on a pic of the offending problem
the rocker trim on the bottom of the step is easily bent if the truck ever got bottomed out on the rocker 2 post lifts are rough on the rockers if you don't pay attention when putting a truck on the lift when i replaced both steps and rockers way back when, we had to bend the rocker out to line up better than it did it takes 4 strong hands to do this
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#9 | |
And some "Basics of Basics" on the subject. http://www.hotrodders.com/forum/basi...it-499546.html Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Everybody probably knows this but me, but I thought I'd share it anyway. I've recently become an "expert"
![]() Hope this helps somebody. We still need a picture from the OP!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 03-26-2018 at 08:49 AM. |
