Old 03-12-2018, 05:44 PM   #1
custom10nut
custom10nut's Avatar
Filler neck Checkvalve?
I searched couldn't find any other threads, so maybe I have the wrong terminology.
Is there such a thing as an insert, to go into the filler neck, to prevent the gas from sloshing out on a Righthand turn, when the tank is full?
All newer vehicles were equipped with the trapdoor the the pump nozzle goes into.
I'm thinking about fabricating an insert, but haven't figured out how to secure it
(No, I'm not going to try to weld it)
Some will say "Just relocate the tank", but I want to leave it in the cab.
Back to my original question.
Is there a vendor that makes/sells an insert like this?
Thanks in advance
custom10nut is offline   Reply With Quote
Old 03-12-2018, 07:00 PM   #2
randy500
Re: Filler neck Checkvalve?
I use a gas cap and it works pretty well.
randy500 is offline   Reply With Quote
Old 03-12-2018, 08:50 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
The correct gas cap avoids this problem. If you make a right turn, it takes enough time for fuel to slosh that a trap door isn't going to help, especially, iirc, there are vent holes in the rest of the reducer in the neck for vapors to be pulled back into the vapor recovery hose. Maybe you don't have those fuel nozzles where you live- they are mostly used in high pollution areas.
~Steven
Simi Valley, CA
Old 03-12-2018, 10:08 PM   #4
custom10nut
I had several different types. The one that works best is the Standard Stainless vented cap (Stant), but it will still leak some on a right turn with the tank full.
The only one I've ever had that didn't leak was not vented, so in the end I couldn't use it.
I didn't mention before that my truck is a 70, so I need the vented cap.
I guess the reason this is now going to be an issue is that I'm about to start prepping to paint my truck, and I don't want to ruin a new paint job.
Old 03-12-2018, 10:21 PM   #5
jocko
jocko's Avatar
Yes, it's a frustrating problem - I've only had one truck do it and the only semi-solution was to replace the cap(s) until one sealed better than the rest. Kinda frustrating. Luckily I wasn't concerned with paint just yet, but the smell about asphyxiated me... So I only turned left from then on.
Old 03-12-2018, 11:03 PM   #6
Boog
laying low
Boog's Avatar
Turn left, go fast. The life of a stock car racer. Yeah buddy!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-12-2018, 11:27 PM   #7
RichardJ
Are you in the habit of clicking away on the nozzle after it first shuts itself off?
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 03-13-2018, 01:00 AM   #8
Warrens69GMC
Warrens69GMC's Avatar
maybe an anti siphon device?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-13-2018, 08:12 PM   #9
custom10nut
Will this fit into my filler neck? And where could I get one?
Old 03-13-2018, 09:24 PM   #10
1968aj
I never fill mine up all the way.
1968aj is offline   Reply With Quote
Old 03-13-2018, 10:11 PM   #11
custom10nut
I agree, and that's what I do, most of the time. But I'm are I'm not the only one who has this issue, and that the factory didn't have this flaw identified. It's most likely why they went with the vented tank in '71-72
Old 03-14-2018, 05:29 AM   #12
697498chevy
Have you tried a Car Quest #10623 ? It works well on my 1969 C 10 . I did replace the gas tank a while back though .
697498chevy is offline   Reply With Quote
Old 03-14-2018, 06:36 AM   #13
A cap has to be pretty lousy to let gas leak out making turns. A sure sign a better cap is needed. I've had them get bad to where they will leak when parked with the left side down when I had just filled up. And that is usually once it sat a while, like when it is hot and needs vented
Old 03-14-2018, 09:42 AM   #14
Keystone_Hate
Mine leaks also on my 72. Interesting note, I found that the rubber gasket for the gas cap is the same size as the one on the gas tank of my 1960 Harley Panhead. So I grabbed one of those from the Harley dealership and it helped a bunch. I think a vented gas cap is going to leak a little bit no matter what, just by it's design. Unless possibly there is one made that has a spring type check valve almost like a thermostat to let pressure seep out but not be completely open all the time.
Keystone_Hate is offline   Reply With Quote
